Whirlpool WFG374LVB1 DSI
9 replies to this topic
#1 gcw1
gcw1
    Yamabushi
  • 74 posts
Posted 22 February 2013 - 09:27 AM
The top burners spark and light but neither the bake or broil ignite. Can smell gas and it clicks when bake or broil is pressed but no spark.
#2 Wingerman
Wingerman
    Yamabushi
  • 77 posts
  • Flavorite Brew:Cuervo Silver and Lemonade
Posted 22 February 2013 - 10:27 AM
The Direct Spark Ignition (DSI) will lockout (No spark to Bake/Broil) if there is a call for ignition at the same time; this condition can happen if the bake/boil combo relay on the ERC (Electronic Range Control) Board has shorted or welded together. First check the relay on the ERC. Normally, if the spark is good to the cooktop, the DSI Board is good. The key question is: Do you have 120V on the J1 connector from pin 4 to 6? This will tell us about the relay. Also, do you have 120V from pin 4 to 7?
#3 RegUS_PatOff
  • 30,229 posts
Posted 22 February 2013 - 11:40 AM
does Broil work ?
#4 Budget Appliance Repair
  • 3,999 posts
Posted 23 February 2013 - 06:58 AM
If either one of the coils in the bake/broil gas safety valve on these are open/bad then you will usually only get one spark/or no spark and it will quit trying to spark and it won't work in broil or bake.
Ohm out both coils on the safety valve and see if one is open.
William Burk (Willie)
Eureka, CA 95501
#5 vee8power
vee8power
    Sōhei
  • 115 posts
  • Flavorite Brew:Folgers
Posted 24 February 2013 - 06:50 AM
Yes, what Budget says is common issue on those. The gas valve/regulator located in the bottom rear has three wire terminals.
http://www.repaircli...0293048/2117182
You'll see 'm here in the picture; think the middle terminal is common. Between it and the other two should be around 200 ohms each.
#6 gcw1
gcw1
    Yamabushi
  • 74 posts
Posted 25 February 2013 - 09:20 AM
Both gas coils ohm out within range. broil doesn't work either keeps trying to start but no visual spark.
#7 RegUS_PatOff
  • 30,229 posts
Posted 25 February 2013 - 02:44 PM
Has this Oven worked OK up till now at this location ?
Has there been any recent House electrical work done ?
Check polarity and ground of Wall Outlet.
#8 gcw1
gcw1
    Yamabushi
  • 74 posts
Posted 27 February 2013 - 01:21 PM
I checked the wiring and the polarity is correct!!
#9 RegUS_PatOff
  • 30,229 posts
Posted 27 February 2013 - 02:04 PM
some info
http://appliantology...ktop-dsi-kr-28/
  • 24,264 posts
Posted 04 March 2013 - 09:30 AM
There was a problem with the bake burner tubes on these units, the alignment with the ignition ports changed over time.  There's an upgraded burner tube out to fix this particular problem.  This may be what's going on with yours.  More info here:
http://fixitnow.com/...that-wont-bake/
Also, more info on the gas valve coils that Willie mentioned:
http://fixitnow.com/...oard-no-change/
