Amana leak
4 replies to this topic
#1 bigbluediesel
bigbluediesel
    Ikkō-ikki
  • Chief Appliantologist
  • 26 posts
  • Flavorite Brew:diet Dr. Pepper :P
Posted 22 February 2013 - 07:53 PM
Amana ALW540RAW - top loader.  This week's problem - it leaks during the spin cycle when a full load is run.  It doesn't do it on a smaller load (when the water level is set below maximum).  Thinking I was a genius, I replaced the tub cover gasket ( http://www.repaircli...40076601/550565 )- didn't help at all...  No visible cracks in the tub or top.  All the hoses are good and tight.  Water appears to be coming from that area, although I'm going to take it apart (AGAIN - I can do this in my sleep now) and run a load with the front covers off.  Any ideas?  I didn't use any sealant / silicone when I put the gasket on.  It went on real easy  - didn't put up a fight at all...  Thanks for any help.
Edited by bigbluediesel, 22 February 2013 - 07:53 PM.
#2 Wingerman
Wingerman
    Yamabushi
  • 77 posts
  • Flavorite Brew:Cuervo Silver and Lemonade
Posted 22 February 2013 - 10:57 PM
Cracks in the pump?
Edited by Wingerman, 22 February 2013 - 11:11 PM.
#3 bigbluediesel
bigbluediesel
    Ikkō-ikki
  • 26 posts
Posted 22 February 2013 - 11:18 PM
I'm going to pull the pump tomorrow - I read one thread about the pump being obstructed with a coin causing it not to pump out before water splashed over the rim during spin cycle.  The leak does appear to be coming from the top and running down the sides.
Thinking about this - this all started when I had the machine gun Amana syndrome (bad helix) - the belt was chewed up something fierce.  The new belt didn't come in a FSP bag.  I'm wondering if it has the required "slip" the stock belt is supposed to have.
I read another thread about Amana having a TSB (what we call them in the automotive field - don't know what they're called here) about a weaker spring on the tensioner - anyone know anything about that?  Part numbers?
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 23 February 2013 - 02:08 AM
2 things to check for:  What was the part number of the belt you installed and is the inner wash basket spinning while it's agitating?  If the inner wash basket is spinning while it's agitating, the brake pads might be worn from the bad helix. The brake not holding the inner wash basket stationary during agitation could be splashing the water over the tub. The incorrect belt could also be causing the water to splash over the tub during spin.
Scott Wolf
#5 bigbluediesel
bigbluediesel
    Ikkō-ikki
  • 26 posts
Posted 23 February 2013 - 08:09 PM
The belt had the correct number on it, but it wasn't in an FSP bag - I'm betting it was a Chinese knockoff.  The brake pads were in place.  When I pulled the pump,  water poured out of the side where it was pressed in place.  I'm guessing that's one of the leaks and the other was the belt.  Anyway - I fixed it where it will never leak again.  I jacked it up and put a Whirlpool in its place. :woot:
