Maytag front end washer won't dispense fabric softener or bleach
dispense Maytag washer MHW6000XW2
12 replies to this topic
#1 themare
themare
    Ikkō-ikki
  • 40 posts
  • Flavorite Brew:Homemade hard cider!
Posted 24 February 2013 - 11:53 AM
Hi, guys!
Well, I bought a Maytag front end washer MHW6000XW2 last Feb. It will not dispense either the bleach or the fabric softener. I have removed the drawer and cleaned it (although it didn't need it). What could be the problem?
#2 Moostafa
Moostafa
    Senpai
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 24 February 2013 - 01:46 PM
Hello, my undispensed friend.  I am curious as to how you arrived at the conclusion that the dispenser did not need cleaning out.  How in-depth did you go with your reaming?   Also, are you certain that the dispenser is being flushed with water?
Allahu Akbar!
#3 sh2sh2
sh2sh2
    Sōhei
  • 212 posts
  • Flavorite Brew:yeunling
Posted 24 February 2013 - 03:12 PM
make sure your cold water inlet valve is clean,
#4 themare
themare
    Ikkō-ikki
  • 40 posts
Posted 24 February 2013 - 04:15 PM
Is the cold water inlet valve where the cold water hose attaches to the washer? (DUH?)
I don't think the dispenser is being flushed with water because the same amount of undiluted bleach and fabric softener remains in the cups.
#5 Moostafa
Moostafa
    Senpai
  • PipPipPipPip
  • 765 posts
Posted 24 February 2013 - 04:55 PM
Hello, my unflushed friend.  I do believe our wise friend, Master sh2sh2, has identified your problem:  the cold water side of the water inlet valve is clogged.  The recommended repair is to replace the valve.  The risky alternative repair is to administer an enema to the inlet screen of the cold water side of the valve.  This carries the risk of flooding due to forcing sediment into the valve, causing the valve piston to stick open and unable to close.  May Allah and his 72 virgins watch over you.
Allahu Akbar!
#6 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,215 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 24 February 2013 - 08:33 PM
set the washer for a cold wash/cold rinse
your washer only has one hot and one cold valve, so if the cold valve is plugged, the washer should not fill for wash either
i would not expect this washer to complete a cycle with the cold valve plugged, as it would get stuck when trying to fill for its cold rinse
you have a diverter motor on the dispensor of this model, i suspect it is stuck or not recieving power from the control
remove the lid of the machine, unplug the washer,wait a minute and plug in washer, the motor and cams on top of the dispensor should rotate and reset on power up
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
#7 Moostafa
Moostafa
    Senpai
  • PipPipPipPip
  • 765 posts
Posted 25 February 2013 - 07:28 AM
Hello, BrntToast, my long-lost friend.  It gives an old Mujahideen warrior's heart much joy to read your technical prose once again.
Allahu Akbar!
#8 themare
themare
    Ikkō-ikki
  • 40 posts
Posted 26 February 2013 - 10:02 AM
Well, once again, you are right on the money! I did what Brnt Toast recommended and he was right. I just ordered a cold water intake valve. Is it hard to put in? I live in a remote area of the Adirondacks and I have to do all repairs myself.
I also sent in a beer donation.
PS: One thing regarding the 72 virgins: Wouldn't it be a riot if those 9/11 terrorists found out the hard way that those 72 virgins were MALE?
#9 themare
themare
    Ikkō-ikki
  • 40 posts
Posted 26 February 2013 - 10:05 AM
Regarding my $10.00 beer donation: An accurate diagnosis from you guys all the time saves me $$$$$ dinero! I figure throwing you guys a case beats a $400.00 repair bill anytime!
  • 24,289 posts
Posted 26 February 2013 - 10:29 AM
Mucho mega domos, Mare!  Always good to know that the problem was solved.  And thanks for your continuing suport!
  • 24,289 posts
Posted 26 February 2013 - 11:01 AM
Piece of pie!
- get your digital camera
- unplug washer
- shut off water valve at wall
- take photo of front of washer and control panel
- remove the top panel of the washer (three screws in back)
- take photo of inside washer
- unscrew fill hoses from back washer-- these attach to the valve that you'll be replacing
- take photo of inside washer showing valve
- remove feed tube from valve inside washer
- remove valve mounting screws from back of washer
- install new valve in reverse order
- pop a cold one and post photos in the Gallery section of this site
Apparently, there is a good case to be made for this interpretation and it is a matter of discussion among Muslims... http://www.albatrus....ns_and_boys.htm
Perhaps our good friend, Moostafa, can enlighten us.
#12 themare
themare
    Ikkō-ikki
  • 40 posts
Posted 27 February 2013 - 06:26 PM
I did it! It was easy! I took pictures like you said, but installing it was so easy it made the pictures look stupid. Thanks so much again!
  • 24,289 posts
Posted 27 February 2013 - 06:37 PM
Stupid for you is brilliant for someone else!  Never underestimate your own repair prowess.
Please post the pics if you git'em.  If you need help, email 'em to me and I'll post 'em:  samurai _at_ appliantology dot org
Also tagged with one or more of these keywords: dispense, Maytag, washer, MHW6000XW2
