Maytag Alantis MAV6200AWW
Spin noise
2 replies to this topic
#1 Patricio
Patricio
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 501 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 24 February 2013 - 01:33 PM
Looked at maytag this morning.  Spin cycle has extremly loud clunking/roaring sound.  Water all on drain pump.  When partially filled with water & put in spin cycle no leakage evident.  Under tub sling pattern of rusty stains evident.  Cannot turn tub by hand very easily but it turns plenty OK under motor power.   My conclusion bearings are bad.   Is it worth repairing, bearings on repair clinic available & not to expensive.  Blue book labor is $200-$245  I want to quote $350 for complete repair.  Advise please
IgonFishn & Tight Lines
#2 Moostafa
Moostafa
    Senpai
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 24 February 2013 - 02:22 PM
Hello, my roaring friend.  Based on your description of the staining under the tub, I would venture to say that you will need the tub seal kit in addition to the bearing.  The leaking tub seal is most likely the reason the tub bearing decayed.  The triple-seal bulletin will assist you in this unholy endeavor.  And if you are not a Muslim, I would recommend that you convert prior to undertaking this repair because you will need Allah and all 72 of the virgin boys to help you with this repair.
Allahu Akbar!
#3 Patricio
Patricio
    Senpai
  • PipPipPipPip
  • 501 posts
Posted 24 February 2013 - 10:55 PM
:turned: I take that as not only No, but HELL NO. :dazzler:
Also tagged with one or more of these keywords: Spin noise
