It's old; but I like working on Classics.
Thanks for your assistance,
William
Posted 24 February 2013 - 04:20 PM
William
Posted 24 February 2013 - 08:48 PM
what part of this micro are you having a problem with ?
Edited by Cactus Bob, 24 February 2013 - 09:26 PM.
Posted 27 February 2013 - 12:08 PM
Temperature control / probe calibration.
Posted 27 February 2013 - 01:18 PM
how far off is it ?
Posted 28 February 2013 - 02:31 PM
how far off is it ?
I would say 40 degrees.
Posted 28 February 2013 - 04:01 PM
49f is not that bad , for a micro temp probe , those things where never all that great in the first place
if there is an adjustment ,
on older ones there was a small sub board mounted below the main board , there would be a "pot "adjustment there , move it a little each way and see what happens
newer ones the adjustment pot is on the mother board , it is the only adjustment there , move a little to adj.
newest ones (1990 and above) have no adjustment
I have found most temp probes are all the same value , so if it plugs in , it works . so if nothing else works , try another probe
but ......to be honest i don't think you have as much of a problem as you thing you do , those probes are always sloppy
Posted 28 February 2013 - 06:14 PM
Actually, this series had one of the more reliable probes typically +/- 5 degrees.
Thanks for the sub-board hint. I also found out that these were not the usual RCA by GE devices but rather RCA by Samsung.
Posted 10 March 2013 - 05:50 PM
I just wanted to close this out by letting everyone know that I was able to get the probe reading within 10 degrees. Apparently generic probes are about 10 KOhms off from the OEM probes; and that's far enough to make a difference. But, this kind of calibration would be so much simpler if the manufacturers provided full range displays -- i.e. including 32 degrees and 212 degrees.
