I have an older Maytag LAT9356AAE top load washer. It's making a roaring noise while in the spin cycle that I am assuming is coming from a bearing. It also needs a tub seal kit as the tub is leaking (this will be the 2nd one). Any clues on the noise? Does it pay to fix (parts)?
MAYTAG LAT9356AAE Washer Noise
#1
Posted 24 February 2013 - 09:42 PM
#2
Posted 24 February 2013 - 10:36 PM
The noise is most likely from one of the lower bearings. Depending on how the machine looks and overall condition it is probably worth fixing, since in my opinion they don't really make a decent top load machine anymore. If this is something you are doing yourself and your cost is just the parts, go for it if everything else is in decent shape. If you do need the center seal, you really need to change the tub bearing also. That isn't where you noise is coming from, but if you are spending the money on the seal you need to replace both parts or you are wasting your time and money, as the new seal won't last. These are the part #'s You will need
6-2095720 stem seal kit 6-2040130 tub bearing kit 22003441 bearing in the top of the brake package (most likely causing the roaring noise) and 200835 lower bearing (if needed)
#3
Posted 25 February 2013 - 06:01 PM
