MAYTAG WASHER (LAT8826AAE) Extra Rinse Cycle
3 replies to this topic
#1 voipman
voipman
  • Chief Appliantologist
  • 11 posts
Posted 26 February 2013 - 02:34 PM
I have a Maytag Washer ( LAT8826AAE) which has an intermittent problem going into the extra rinse cycle when it shouldn't.  I have the extra rinse button out and I find that sometimes after the last spin the timer keeps going and does the extra rinse.  Any advise on where to look for this problem?
Thanks in advance.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 27 February 2013 - 12:11 AM
When you say you have the extra rinse button out, do you mean you turned off the switch or you removed the switch from the washer?
Scott Wolf
#3 voipman
voipman
  • 11 posts
Posted 28 February 2013 - 02:23 PM
The Extra Rinse button is a push button.  The button is out and not enabled or off.  The Extra rinse sould not come on.
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 28 February 2013 - 02:31 PM
Did you test that button switch for continuity with your meter?  With the button pressed in and on, it should show continuity and the meter should beep,  with the button out and off you should get nothing and no beep. If  the switch tests good, your problem is the timer.
Scott Wolf
