JennAir Electric Cook Top #JEC0536ADB, Fried connector at large burner.
5 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 240 posts
  • Flavorite Brew:Root Beer
Posted 26 February 2013 - 07:25 PM
O.K. So I went to replace the large center burner only to find that the new part appeared to be damaged, so I re-ordered a new one.  When I had the top removed I discovered a fried terminal on one of the wire connectors, and was wondering if I should replace the entire wire or crimp on a new connector?  and what connector/part number would it be.  The burner i was replacing is P/N 74010159.  The wire that is questionable was red, but it was trapped between the glass and the burner, since when? don't know.  In the attached photo the wire turned white where it was trapped.  Also I've attached a photo of the new damaged burner, I'm returning because I assume this would be burning out in short order?  Oh yeh, i also chipped the glass and will be order a new glass top, needless to say not a very profitable project, oh well...
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,749 posts
Posted 26 February 2013 - 07:43 PM
I would think you can crimp on another connector if the remaining wire is not grounded/damaged etc. test for grounding with your meter. Maybe a job for a megger. Then again since you already gotta pay money out of your pocket, maybe there is more profit margin to replace the wire set. They get a new wire, you get a little more profit...win-win.
Edited by DurhamAppliance, 26 February 2013 - 07:49 PM.
#3 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 26 February 2013 - 07:47 PM
I still haven't purchased a megger, do you recommend one?
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 1,749 posts
Posted 26 February 2013 - 07:55 PM
I don't have one neither. Still trying to figure it out. If i understand them correctly I think one may be beneficial in your scenario. I actually included it in my post just to get responses from those more familiar with them in order to help me make a decision as well.
#5 RegUS_PatOff
  • 30,278 posts
Posted 26 February 2013 - 10:24 PM
... if the remaining wire is not grounded/damaged etc.
if the copper wire is overheated (dark orange color), cut-back until it's copper color
  • 24,346 posts
Posted 27 February 2013 - 06:48 AM
This is a common failure from the stamped-out terminal connections getting weak over time creating a loose connection.  And the rule with 'lectricity is that lose connections make heat, sometimes lots o' heat, like you're seeing there.
After you've cut back to good copper and you're ready to re-terminate the wire, review the diagrams in The Fine Art of Wire Terminal Crimping album ==> http://appliantology...minal-crimping/
Although a megger would not be a useful instrument in this situation, it is in others, like assessing the condition of the insulation on compressor motor windings.  Here's the megger I use, inexpensive and goodnuff ==> http://amzn.to/R8LDGd
