I would like to know how to manually advance the timer. Engaging the start lever turns the cam but doesn't advance the cycle.
#1
Posted 27 February 2013 - 10:54 PM
#2
Posted 28 February 2013 - 02:35 AM
some info:
http://appliantology...fl-fccw3000fs2/
http://appliantology...coin-fccw3000f/
let me know if this doesn't help the problem ..
#3
Posted 28 February 2013 - 11:48 AM
manual Timer advance ...
not normally, but possible with (2) jumper wires
#4
Posted 28 February 2013 - 07:46 PM
Thanks for the info Reg. Nothing wrong with the washer now but I've worked on it before and had to wait for the entire cycle to run. Same with the matching dryer (FCED3000ES0). You can advance the timers on the older coin-op washers to any part of the cycle. I think this is the possible problem they had because the washer worked normally when I ran it. Posted above by Reg http://appliantology...fl-fccw3000fs2/
#5
Posted 01 March 2013 - 08:35 AM
check the back side of the timer, If I remember correctly on these coin-op front loaders where the cycle position pointer is behind the clear plastic window there is an extended boss or screw slot that you can use to advance the timer manually, (you do have to remove the top to access it of course).
Eureka, CA 95501
#6
Posted 01 March 2013 - 10:40 AM
Thanks, I will try that.
#7
Posted 02 March 2013 - 10:28 AM
Remove the top ( screws at rear, 9/16" nut in coin box) and advance timer with flat head from the rear...
- Samurai Appliance Repair Man and SANTA like this
Also tagged with one or more of these keywords: Timer
