frigidaire dryer gleq2152es1
WONT START W/ HIGH TEMP
7 replies to this topic
#1 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 167 posts
  • Flavorite Brew:guiness
Posted 28 February 2013 - 12:41 PM
When a cycle is selected with high or normal heat,the drying/cool down/press saver/ clean lint filter lights flash three times and beeps,there is no display.If low heat is selected,dryer starts and the time is displayed.it's as if the door is open and start is pressed.this happens on all cycles,and only when a high temp is selected.this is a stack unit squeezed into a closet in a tiny bathroom.removing vent hose has no effect on problem.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 28 February 2013 - 01:01 PM
Most likely a bad electronic control board.
http://www.repaircli...4523200/1154933
Scott Wolf
#3 RegUS_PatOff
  • 30,700 posts
Posted 28 February 2013 - 01:51 PM
from the Operating Instructions:
"To change the selection after the cycle has begun, press Pause / Cancel twice,
select a new cycle and press START.
Just turning the knob to another selection will not change the cycle.
The signal will beep and the status lights will flash,
but the original cycle will continue."
"If changes are attempted after the cycle starts, the status lights will blink,
the signal will beep and “Err” will be displayed.
To change a setting after the cycle starts, press Pause/Cancel once,
adjust the setting and press START to resume the cycle."
#4 tommytech
tommytech
    Sōhei
  • 167 posts
Posted 28 February 2013 - 03:17 PM
thanks guys.1 question:the tech sheet states to self test /diagnose mode ,set cycle selector to the 3 o'clock position.but there is no indicator or off,so how do you determine the correct position to initiate diagnostic mode?
#5 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 28 February 2013 - 04:26 PM
Turn the big knob ( the cycle selector) to the DELICATES cycle.
Scott Wolf
#6 tommytech
tommytech
    Sōhei
  • 167 posts
Posted 01 March 2013 - 07:26 PM
aaah,thanks Scott
#7 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,215 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 01 March 2013 - 09:52 PM
remove the front panel(control panel) and look at the heater relay on the board
these models burn up the heater relay
the symtom of a burnt relay is the machine only runs in air fluff
if the relay is cooked, you will have to replace the board,and crimp new ends on the wires if they are burnt up,otherwise the bad ends will damage the new board over time
Edited by BrntToast, 01 March 2013 - 09:55 PM.
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
  • 24,716 posts
Posted 02 March 2013 - 07:46 AM
Control board part link ==> http://www.repaircli...ber=GLEQ2152ES1
User-Control-and-Display-Board-134523200
