JDS9860aap downdraft switch
5 replies to this topic
#1 amvisel
amvisel
  • 3 posts
  • Flavorite Brew:wine!
Posted 28 February 2013 - 01:14 PM
My Jenn-air duel fuel range's downdraft switch does not work.  all the rest works-oven, convection fans, stove top burners and lights on the control board.  It seems to be just the downdraft fan.  Could it be the rocker switch or does it sound like the relay board....please say rocker switch!
Thanks in advance!
#2 RegUS_PatOff
  • 30,216 posts
Posted 28 February 2013 - 02:21 PM
... It seems to be just the downdraft fan.  Could it be the rocker switch or does it sound like the relay board...
could be either of those (3)..
would need to do some tests of each component
16026780.pdf
  • 24,243 posts
Posted 28 February 2013 - 02:55 PM
Those rocker switches are a common fail item ==> http://www.repaircli...mber=JDS9860AAP
#4 amvisel
amvisel
  • 3 posts
Posted 28 February 2013 - 04:58 PM
You guys helped me years ago disect a subzero so that I knew what part to order from you and then all I had to do was have a repair guy come install it- and I really appreciated it!  Of course I hope it is only the rocker switch but can you lead me how to take off the front panel to get to remove the switch to test (saw the video on how to test) and also how to get to the relay board I saw mention of that others have found burned?  I'm just a girl :) so I am going to have a friend help me undo the thing and do the testing...
#5 RegUS_PatOff
  • 30,216 posts
Posted 28 February 2013 - 05:39 PM
http://appliantology...s9860-16026016/
#6 amvisel
amvisel
  • 3 posts
Posted 28 February 2013 - 06:03 PM
Thank you so much RegUS_PatOff!  Lovely evening reading with a glass of wine!!
