Hotpoint SxS HSS25GFPA
Hotpoint HSS25GFPA WR55X10942 WR60X10074
5 replies to this topic
#1 RussTech
RussTech
    Kohai
  • 302 posts
  • Flavorite Brew:Heineken
Posted 01 March 2013 - 02:02 PM
Complaint was Freezer and Beer Section not cold. Tech (not me!) replaced mainboard with board # wr55x10942. Refrigerator operation was too his satisfaction. House was empty so no feedback from cust. Get a call back, freezer is cold, beer section is warm. Goes back out, says evap fan is running super slow. Orders evap fan. I go to install evap fan and discover damper is closed. Opened up the damper, cust calls back the next day saying fridge is warm still. Im thinking its either misalignment on the hinge leaving the light switch open and making the board shut the damper, or original fan has taken out new mb. Or both. All I need is better diagnostic info for this board so I get in there with a meter and test it out. Ive searched and searched for it, and I swear it was on this site, but I cant find it. Can any of you venerable masters help me out?
Thank you in advance.
Russ
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,707 posts
Posted 01 March 2013 - 03:19 PM
I didn't read anything about testing/replacing ff thermistor...thermistors are usually suspect no. 1...  btw do  either of the resistors under the j2 connector  appear to be burned out?
also btw the fan usually starts slow then speeds up after a minute or two
Mainboard diagnostic manual http://appliantology...gnostic-manual/
Edited by DurhamAppliance, 01 March 2013 - 03:23 PM.
#3 maytagman
maytagman
    Ikkō-ikki
  • 56 posts
  • Flavorite Brew:Spotted Cow
Posted 01 March 2013 - 03:29 PM
Check the instruction sheet that was with the board. If you have the earlier encder model you need to clip one of the wires when you install the new board. If you dont I believe the damper stays closed like it does with the light staying on. Check the serial numbers on the sheet.
It is the thermistor wire in pin 2 of the J1 connector.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 1,707 posts
Posted 01 March 2013 - 03:38 PM
Maytagman is correct, if your model is an encoder model...ie, it has knobs instead of digital controls, check the serial number and compare it with those listed on the instruction sheet provided with the board. As a matter of fact, here is the info courtesy of Sensei Reg:
NOTE: This step is ONLY applicable for the following models:
All BOTTOM FREEZER models
(and anyENCODER models with the following serial number prefixes:
TD2, VD2, ZD2, AF2, DF2, FF2, GF2, HF2, LF2, MF2, RF2, SF2
Edited by DurhamAppliance, 01 March 2013 - 03:40 PM.
#5 RegUS_PatOff
  • 30,188 posts
Posted 01 March 2013 - 08:16 PM
http://appliantology...tallation-info/
#6 RussTech
RussTech
    Kohai
  • 302 posts
Posted 02 March 2013 - 02:08 PM
Originally, it was a burnt pin on the compressor relay. Dead box. Also, it sure did turn out to be the wire on the J1 connector pin 2. Clipped the wire, plugged her in, and she was blasting cold air through the damper into the FF side. Thanks fellas.
