Maytag MAH550BWW and LR code
maytag lr motor locked rotor control board
4 replies to this topic
#1 madtripper
madtripper
  • 17 posts
  • Flavorite Brew:Czechvar
Posted 01 March 2013 - 08:12 PM
Greetings all and fortunately, this is a tale of success however since my symptoms were slightly different than previous warriors, I thought I would post my story.
My washing machine began displaying the LR code occasionally.  I was usually able to get it to finish the load by unplugging and allowing proper rest time.  I knew there were issues on the horizon but I managed to limp by until last weekend.  I put my last load into the machine and this time, it refused to finish it's job.  I started my research and found a few different scenarios but all of them seemed to result in purchasing the controller and motor kit.  My serial number starts with B7 and I'm not sure what year it is or any of that good stuff especially since I basically got the machine for free.  It has been a great washer for myself and 3 children so I really hated the idea of replacing it.  My wallet also resented the idea.
I performed the spin diagnostic with no errors.  As a matter of fact, I utilized this to get a couple of loads finished during it's period of non -cooperation.  The agitation portion of the sequence worked fine as did the quick cycle diag.
I checked the leads across the water valves and they appeared fine.  I also checked the motor for resistance values according to the diag sheet, which checked out.
I pulled the control board and only noticed a few oddity's.  One of the large capacitors appeared to be bulging (I have replaced bulging caps on motherboards when there was a rash of them a few years ago) and I also had some residue on a few resistors that resembled a leaky battery.
At this point I was kind of at a loss but took the advice given to so many with the same issue and ordered the kit overnight shipping.  I figured worse case, I was out the cost of shipping if my decision was incorrect.
I ordered the kit around 7pm and it arrived at 11am the next day.  I can't say enough about the help and quality customer service that RepairClinic.com provides.
I replaced the components in about 45 minutes following the instruction sheet provided.  There were a few changes with the kit I received so I wanted to comment on that.
The default connection to the control board which I believe is labeled as "main" would fit with my existing connnection however this would bypass the newly added ac filter.  I tried it this way and the spin diag worked fine.  I felt like I should follow the instructions however so I pulled the molex connection apart and made the filter part of the circuit as advised.  I retained everything just in case I needed to bypass it for some reason but I feel comfortable with following the instructions.
I already finished my first load since the repair and all appears sound.
Tripper
Drive Motor and Control Board kit ==> http://www.repaircli...mber=MAH5500BWQ
Edited by Samurai Appliance Repair Man, 02 March 2013 - 10:33 AM.
Added part link to the drive motor kit
Model 110-20056991 :(
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 01 March 2013 - 08:25 PM
Glad you fixed it.
Scott Wolf
#3 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 02 March 2013 - 09:14 AM
for future reference with a serial number of b7 you most likely did not need the full kit, just a new motor control board.
#4 madtripper
madtripper
  • 17 posts
Posted 02 March 2013 - 10:15 AM
I went back and forth with RepairClinic on that.  The first service rep told me control board only.  The second said I needed the kit and when I asked, he told me if I had a B8 serial number instead of the B7, the board would be appropriate as opposed to the kit.  I have retained the motor as I believe it would have worked with the new board.  Additionally, the price difference between control board solo vs. the kit was about $10.
Thanks for the input.
Tripper
Edited by madtripper, 02 March 2013 - 10:16 AM.
  • 24,716 posts
Posted 02 March 2013 - 10:34 AM
Great repair story, madtripper, domo for posting that!  I'm sure it'll be helpful to others coming along with a similar problem in the future.  :)
Also tagged with one or more of these keywords: maytag, lr, motor, locked rotor, control board
