Suds alert! model wfw9500two1
dreaded suds and f35
19 replies to this topic
#1 arrow 1
arrow 1
    Yamabushi
  • Chief Appliantologist
  • 64 posts
  • Flavorite Brew:Texas Tea
Posted 02 March 2013 - 10:33 AM
I have a customer that called me after 4 other techs had been out, They replaced the flow switch, pressure switch 3 times, dispenser actuator . Still no solve. pump trap cleaned. Any one got a great war story on this? That might help him and me before i go out f35 and suds codes
Edited by arrow 1, 02 March 2013 - 10:34 AM.
#2 jumptrout
jumptrout
  • 1,126 posts
  • Flavorite Brew:Coors Light
Posted 02 March 2013 - 10:51 AM
This might be too elementary a question but, what type and how much detergent is being used?
  • 24,214 posts
Posted 02 March 2013 - 10:54 AM
Not elementary at all!  Using HE detergent in the proper amount is fundamental to the proper operation of the this machine.
#4 Strathy
Strathy
    Kohai
  • 382 posts
  • Flavorite Brew:DP.
Posted 02 March 2013 - 10:55 AM
Pull the hose off the Analogue Pressure Switch at the top right and blow through the hose back into the machine.  Is that clear?
If so - and that is the switch that has been replaced 3x (why 3x ... lol!), then I would pull the back off the machine and remove the plastic assembly that the hose connects to at the bottom back of the outer tub and look inside and see if there are any coins or other junk that might be periodically blocking the pressure hose.
If that is all clear, then you are hunting for a wiring problem or a CCU issue.
Make sure there are not any other codes saved in the control.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#5 Dan Webster
Dan Webster
    Paw Paw
  • 1,314 posts
  • Flavorite Brew:Busch
Posted 02 March 2013 - 11:23 AM
Pin hole in the hose from analog pressure switch to control?
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a Beer: http://web.me.com/ze...man18007260692/
#6 arrow 1
arrow 1
    Yamabushi
  • 64 posts
Posted 02 March 2013 - 11:53 AM
Ok thx will report back
#7 RegUS_PatOff
  • 30,198 posts
Posted 02 March 2013 - 12:16 PM
what time frame ?
was it working each time when they left ?
... what type and how much detergent is being used?
#8 mark mac
mark mac
    Sōhei
  • 190 posts
Posted 02 March 2013 - 01:43 PM
If everything has been replaced u have a bad ccu
#9 arrow 1
arrow 1
    Yamabushi
  • 64 posts
Posted 02 March 2013 - 03:36 PM
Customer has been using he detergent. Checked all suggested here. He said it did not work after other techs left. Turn it on fills with water then goes to suds error and then f35. Ran diagnostics no other codes. ran steamer diagnostic said yes it is ok. It can be cancelled and will drain. pulled hose on both ends of pressure switch it is clear. Probably ccu??
#10 Strathy
Strathy
    Kohai
  • 382 posts
Posted 02 March 2013 - 05:31 PM
That has always been the analogue pressure switch for me. You sure the other company actually changed it?
#11 nickfixit
nickfixit
  • 1,964 posts
Posted 02 March 2013 - 08:55 PM
Perhaps they were using old stock, as in no good,  or not the correct Pressure switch. Verify the Model number then make sure you get the current part.
#12 RegUS_PatOff
  • 30,198 posts
Posted 02 March 2013 - 11:40 PM
The manufacturer has replaced part number W10156252
with this item, part number W10415587
http://www.repaircli...R=154&N=1938628
#13 arrow 1
arrow 1
    Yamabushi
  • 64 posts
Posted 03 March 2013 - 09:04 AM
Yes customer had part package W10415587 and his old switch. Yes I have replaced quite a few of these switches and worked each time. I had one of the switches on truck and even put it on with no results.
#14 mark mac
mark mac
    Sōhei
  • 190 posts
Posted 03 March 2013 - 11:44 AM
Seen this problem ,plenty of times ,beside the switch its the ccu ive replaced it all before and it was the ccu
#15 nickfixit
nickfixit
  • 1,964 posts
Posted 05 March 2013 - 10:46 PM
Yep, the CCu is the only thing left.
#16 arrow 1
arrow 1
    Yamabushi
  • 64 posts
Posted 06 March 2013 - 06:32 PM
Just an update: It was the ccu. Thanks for all the help
#17 Samurai Appliance Repair Man
  • 24,214 posts
Posted 07 March 2013 - 06:53 AM
Good to know! Domo for posting the outcome! What's the part number of the CCU you replaced?
#18 arrow 1
arrow 1
    Yamabushi
  • 64 posts
Posted 24 March 2013 - 10:20 AM
Sorry about posting to your request so late. Part # 8183196
#19 Samurai Appliance Repair Man
  • 24,214 posts
Posted 24 March 2013 - 02:15 PM
Domo for posting that info, Brotha arrow!  That part number is for the MCU (motor control board).  But you mentioned replacing the CCU, which is part number W10156258.  Just wondering if you made a typo on the CCU or if you actually did replace it but accidentally posted the part number for the MCU.
I know, makes my head spin, too!   :wacko:  Can you imagine what this will do to a Grasshopper who comes along later and reads this?  That's why I try to keep it as clear and easy-to-follow as possible.
#20 arrow 1
arrow 1
    Yamabushi
  • 64 posts
Posted 07 April 2013 - 06:13 PM
Yes it was the mcu duh!
