GE GDWF100R10BB Diswasher not filling
5 replies to this topic
#1 Zorthgo
Zorthgo
  • 2 posts
  • Flavorite Brew:Heineken
Posted 02 March 2013 - 12:22 PM
Hi Guys, I am new to the site. My washing machine is driving me crazy, I hope someone could point me in the right direction.  :thumbsup:
Problem: Dishwasher won't fill.
This is what I have tried so far to diagnose the problem:
  1. Checked the inlet valve by running 120V through it. It started up fine and filled the dishwasher with water. (I am assuming the valve is ok!)
  2. I bypassed the float switch, but the inlet valve did not start up.
  3. Because the inlet valve did not start up when the float switch was bypassed, I measured the voltage that it was receiving from the ... Wherever ... and it was only 5V. Correct me if I am wrong but I though that the inlet valve operates at the 120V range.
So, as a conclusion, I am assuming that the problem is with whatever sends the voltage to the inlet valve. I don't really know what that is. Can anyone shed a light on my situation. Are any of my assumptions above not correct? Where should I go from here?
Thanks for the help!  :wink:
  • 24,296 posts
Posted 02 March 2013 - 12:49 PM
Good job troubleshooting this far!
Here's the minimanual for your dishwasher ==> http://appliantology...her-minimanual/
Jump on up to the J2 connector on the control board and see if you're getting 120vac between pins 5 and 9.  If not, the the circuit board is is toast.
#3 RegUS_PatOff
  • 30,262 posts
Posted 02 March 2013 - 12:54 PM
actually between J2 pin 5
and through the Door Interlock Switch :whistling:    to J1 pin 1 (neutral)
  • 24,296 posts
Posted 02 March 2013 - 03:27 PM
Oops! Missed that pesky little switch. Good catch, Reg!
#5 Zorthgo
Zorthgo
  • 2 posts
Posted 02 March 2013 - 05:03 PM
Thanks for the help guys! The mini manual really came in handy!  :woot:
Strange thing is that when I reconnected everything it just worked! Maybe it was a loose cable or something. You guys rock!  :rocker:
  • 24,296 posts
Posted 03 March 2013 - 06:55 AM
Thanks for letting us know!  It was probably just an oxidized contact on one of the molex wire harness connectors.  Good job!
