WHP WASHER MHWZ400TQ00
9 replies to this topic
#1 DJAPPLIANCE
DJAPPLIANCE
    Ikkō-ikki
  • Chief Appliantologist
  • 56 posts
Posted 05 March 2013 - 11:38 PM
Need help had the above unit showing an f-20 code well I replaced the pressure switch after m the pressure line is clear aking sure the unit wa clear. I had a ccu even installed it and still getting the dang f-20 any help
#2 RegUS_PatOff
  • 30,300 posts
Posted 06 March 2013 - 01:51 AM
F20 NO WATER DETECTED ENTERING MACHINE
OR PRESSURE SWITCH TRIP NOT DETECTED.
Is there water entering the Washer ?
Are the Water Valves clogged ?
Using any "funny" Water Inlet Hoses ?
Have you tried a
Cold Wash ?
Warm Wash ?
#3 jumptrout
jumptrout
  • 1,143 posts
  • Flavorite Brew:Coors Light
Posted 06 March 2013 - 06:57 AM
If water os entering the machine,check the pressure switch hose for a pin hole or gunk where it attaches to the tub.
#4 DJAPPLIANCE
DJAPPLIANCE
    Ikkō-ikki
  • 56 posts
Posted 06 March 2013 - 08:39 AM
I have changed the pressure switch and the ccu blew through the pressure hose and all ok?water is entering the machine its putting to much in it
#5 Skiter29
Skiter29
    Kohai
  • 315 posts
Posted 06 March 2013 - 12:38 PM
replace pressure switch hose. blowing thru it is not gonna tell u if there is a pin hole in it.  i have replaced many of these that were rubbing against the tub do to poor installtion at the plant.
#6 Peter Trombley
Peter Trombley
  • Master Appliantologist
  • 1 posts
Posted 11 March 2013 - 12:08 PM
if it fills and stops, my guess is they sent a bad part
#7 AppGuy
AppGuy
    Kohai
  • 350 posts
Posted 12 March 2013 - 10:31 AM
do those have a pressure switch that clicks when full?  do you hear a click?  maybe load test the wires running to the switch?  Are you able to stop water flow by blowing into the hose while it is filling?
Edited by AppGuy, 12 March 2013 - 10:32 AM.
#8 Vets Appliance
Vets Appliance
    Ikkō-ikki
  • 58 posts
  • Flavorite Brew:Caffeine
Posted 13 March 2013 - 08:33 PM
My first move would be to unhook both ends of the air tube and trim them back 3/4 of an inch each. If that doesn't help then sometimes I'll take the top end of the tube off, fill the unit with water, blow into the tube until I get bubbles and then sit there with my tongue sealing the end of the tube for 2 minutes or so while I read a book on my phone or tablet.
After waiting, I blow slowly to see how long it takes to get bubbles again. This tells me if water has crept up the tube, revealing a pinhole leak.
The only other thing that leaps to mind is those wires and their connectors. Remember to not only check continuity but wiggle the heck out of those wire while you're checking it so that any internal breakage in the wires will be detected.
Edited by ScottsApplianceRepar, 13 March 2013 - 08:35 PM.
Me: "Why are my customers always so happy to see me arrive but then say they hope to not see me again anytime soon?"
Joe Customer: "Because we have to pay you to leave."
#9 DJAPPLIANCE
DJAPPLIANCE
    Ikkō-ikki
  • 56 posts
Posted 21 March 2013 - 02:15 PM
i know this reply is late but man I feel so dang stupid you will never guess what the issue was? Lets just say this I had some new tubing (don't know why I didnt do 1st) but I took old hose out and installed new hose,went ahead and ran while I took the time to look at the hose and about the same time I found the very small rub spot in hose the water shut off and went to washing :-) I guess we all over look the smallest things
  • 24,360 posts
Posted 21 March 2013 - 10:20 PM
Domo for letting us know!   :dazzler:
