K-Aide KUDI02FRSS0 -- poor sealing and bad touchpad
3 replies to this topic
#1 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
  • Flavorite Brew:Blue Moon or Lion Imperial or Shiner Bock
Posted 06 March 2013 - 01:32 PM
Attached File  Picture0306131215_2.jpg   44.89K   13 downloadsAttached File  Picture0306131215_1.jpg   74.83K   13 downloadsComplaint was non-responsive/intermittently responsive touch pad. User interface was warped upwards.
Took off outer door, door latch/switch assembly was covered with white gunk.
Taking the latch assembly off I can see that the inner door is really bent where door latches.
There's no obvious reason for this bend -- I took the unit out a few inches and observed the door closing from multiple angles -- it's striking correctly and the installation wasn't bad. No torquing or twisting of door on the hinge.
My question  -- am I right in thinking the bent door is going to cause problems?  Or can I solve the moisture/hot air issue with a new gasket and leave the door as is.
Difficulty: customer will replace if a new door is needed and will repair if it's just the gasket and touchpad.
#2 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 897 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 06 March 2013 - 08:35 PM
These units are infamous for bad ribbons/touchpads. IMHO, I would not be eager to replace the inner door -- just the console.
Mother Teresa
#3 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 06 March 2013 - 09:27 PM
Thanks!  I didn't know about this particular issue. Given how much crud has gotten inside the latch and touchpad, should I also replace the ribbon connector that goes from the touch pad to the control board?  That's on the parts drawing as a separate part and I would assume it's also been compromised.
#4 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 897 posts
Posted 07 March 2013 - 08:22 PM
I guess it wouldn't hurt to have it on hand when you go back. I carry that ribbon on my truck, so I guess it is a common part failure...
Mother Teresa
