Food Grade Grease Specification?
Embroiderr
Hi,
My repairs on my Kenwood Prospero (MX260/KM260) continues -  I received the spare parts and installed them, however I am now in need of re-greasing the mixer head.  Does any one know the specifications for the food grade grease that I should use?  I want to be able to buy something locally in New Zealand rather than having to import more than I need from the UK.
Joanne
  • certified tech group 51
  • Embroiderr
  • jumptrout
Look for  Haynes 500 food grade grease.....Rated for 500 degs...F........also good for oven door hinges................
