To the Dojo,
This laundry center won't pump out. It has an 88-Watt pump, and is drawing .75-ish amps. Tub-to-pump hose is clear, and I can blow water out of the pump-to-drain hose. Am I crazy: does this hose have a check valve; I am getting the correct amperage, right? Any help will be greatly appreciated.
Thanks in advance,
Tyrus
