Troubleshoot modern appliances with confidence…
RedToryTy
KM (Frigidaire) laundry center 417.98702892 not pumping out
8 posts in this topic
To the Dojo,
This laundry center won't pump out. It has an 88-Watt pump, and is drawing .75-ish amps. Tub-to-pump hose is clear, and I can blow water out of the pump-to-drain hose. Am I crazy: does this hose have a check valve; I am getting the correct amperage, right? Any help will be greatly appreciated.
Thanks in advance,
Tyrus
seems OK
How's the Impeller ?
does the Pump turn when powered ?
I used the conversion formula from my appliantology textbook; I'm reading out okay.
... The instructor showed the exact one I carry: the Kill-a-watt meter:
that's the same one I use around the house ... can accumulate wattage usage
Wife: "How much is that beer cooler in the garage costing us per month  ?"
Store owner: "How much is your Pepsi machine costing me per month ?"
Don't forget to check the door lock assembly on these; in particular, the door lock assembly wax motor which is in parallel with the pump motor. An intermittent/shorting door lock assembly can throw the pump a curve ball.
If you bail the basket so that it's empty, will the washer spin? If not, excellent chance that your door lock assembly is bad as Brother Wingerman points out.
Are you getting any error codes?
check valve is built into the drain hose on the friggys
Edited by BrntToast
