maytag dryer won't start
4 replies to this topic
#1 FISHIZZLE
FISHIZZLE
    Ikkō-ikki
  • Chief Appliantologist
  • 42 posts
  • Flavorite Brew:laughing lab
Posted 09 March 2013 - 10:05 PM
Maytag model#MED583TW0  I'm having issues with this dryer and I'm needing some insight.  The problem I'm having is that it just won't start.  You can turn it to either time dry or auto dry, press the start button, and no go!  Here's where it gets wierd...the timer will continue to tick down, it will continue to tick through the "cool down" section, and then it will start up in the "wrinkle free" section.  I'm thinking it's the timer but not sure.  Thanks!
#2 RegUS_PatOff
  • 30,229 posts
Posted 09 March 2013 - 10:32 PM
... MED583TW0
might that be a
MED5830TW0 ?
doesn't make much sense, but then,
yes, it could be a bad Timer
Any part ordered from RepairClinic
can be returned for a refund (less shipping)
including installed electrical parts
http://www.repaircli...R=154&N=1180505
#3 Vets Appliance
Vets Appliance
    Ikkō-ikki
  • 58 posts
  • Flavorite Brew:Caffeine
Posted 13 March 2013 - 08:14 PM
Wait, the timer motor keeps the knob turning right through the off position and then into another cycle beyond the off position?
And she won't start no matter where the timer is pointing?
Check the schematic (I can't find one online) to see if the timer motor is in series or parallel with anything crucial to the dryer's ability to start. Check to see if the timer motor has switched power or switched neutral. If there is a short some place then that may, I say may, be causing the timer motor to keep going and, at the same time, interfere with the unit's ability to start.
It all depends on how it was wired.
Edited by ScottsApplianceRepar, 13 March 2013 - 08:14 PM.
Me: "Why are my customers always so happy to see me arrive but then say they hope to not see me again anytime soon?"
Joe Customer: "Because we have to pay you to leave."
#4 certified tech group 51
  • 1,977 posts
Posted 13 March 2013 - 09:51 PM
 Sure looks like a Maypool.....If the parts list is correct , I would look for the thermal fuse....P/N 3392519.......Opens the circuit  of the motor ........Some models, the timer runs when the door is closed..... some timers run all of the time, door open or closed....  For advancing to the next cycle, you could have an option button  that lets the timer advance  from a heated cycle ( With cool down ) to the wrinkle -free cycle ( stops and starts to keep items ' wrinkle-free' ).... Use your wire diagram.......
#5 Vets Appliance
Vets Appliance
    Ikkō-ikki
  • 58 posts
Posted 14 March 2013 - 08:58 AM
CTG51 has an interesting point. Is that "Wrinkle Free" a new cycle or just an anti-wrinkle feature such like "Tumble Fresh" is on the Whirlpool Duet washer?
If it's just an anti-wrinkle feature then ignore it and treat it the same as any no-start situation where you have power to the timer.
