Whirlpool Direct Drive # TAWS850PQ, Transmission Issue?
8 replies to this topic
#1 AlexM
AlexM
    Kohai
  • Chief Appliantologist
  • 262 posts
  • Flavorite Brew:Root Beer
Posted 09 March 2013 - 11:07 PM
I thought this might be a simple motor coupling job, it wasn't.  There was a humming noise from the motor and the drain pump was clear and good, the coupling was intact, and when the motor was disconnected from the pump and the coupling it ran fine.  When hooked up the motor couldn't turn the basket, is it that simple that the transmission is bad?  if so, is that likely not worth fixing?  the machine is around 7 years old.  What is the scientific way of checking for a bad tranny?  there was no oil or mess in or on the unit.
#2 RegUS_PatOff
  • 30,689 posts
Posted 10 March 2013 - 02:36 AM
... the motor couldn't turn the basket
in neither direction ? (Agitate / Spin)
Can you turn the Washer Coupling in either direction ?
#3 nickfixit
nickfixit
  • 1,988 posts
  • Flavorite Brew:Glen Livit
Posted 10 March 2013 - 08:03 AM
check for something caught between the basket and the outer tub.
#4 AlexM
AlexM
    Kohai
  • 262 posts
Posted 10 March 2013 - 09:10 AM
Thats a great idea.  Should i just pull off the tub ring in order to look down the sides? or do I need to pull out the basket?
#5 AlexM
AlexM
    Kohai
  • 262 posts
Posted 10 March 2013 - 09:27 AM
I could only turn the washer coupling one direction, does that mean something?
#6 fairbank56
fairbank56
    Sōhei
  • 185 posts
Posted 10 March 2013 - 09:49 AM
  CCW is agitate, CW is spin. What you really need to do is run it in spin with the cabinet removed and lid switch bypassed. Observe the clutch hub while in spin mode. If it's rotating, the gearcase is ok, but the clutch is slipping or the brake cam driver is broken. A slipping clutch can be caused by clothing between the tubs, a worn clutch or something with the basket drive. If the clutch hub is not rotating during spin mode, it's likely a gearcase issue.
Eric
Edited by fairbank56, 10 March 2013 - 09:50 AM.
#7 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,215 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 10 March 2013 - 03:21 PM
remove the agittor and make sure the drive block hasn't stripped out, this causes the inner basket to drop down and bind
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
#8 dimitri77565
dimitri77565
    Yamabushi
  • 61 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 10 March 2013 - 06:51 PM
Your pump could be bad also. Disconnect pump, test then disconnect coupler .
The impeller in the pump freezes.
#9 Vets Appliance
Vets Appliance
    Ikkō-ikki
  • 58 posts
  • Flavorite Brew:Caffeine
Posted 13 March 2013 - 08:24 PM
I've had a locked motor issue from a sock in the pump. Easiest way to test that is disconnect only the pump and try to spin.
If I take out the pump and motor and still can't turn the coupling to make the basket spin by using one finger on each hand, shoving with both hands, I suspect either something jamming the inner basket, a bad transmission or maybe a locked up brake. If the brake lining comes apart sometimes the bits and pieces can get stuck in there.
Me: "Why are my customers always so happy to see me arrive but then say they hope to not see me again anytime soon?"
Joe Customer: "Because we have to pay you to leave."
