LG washer help
wm2010cw
14 replies to this topic
#1 bayouboy
bayouboy
    Ikkō-ikki
  • Chief Appliantologist
  • 35 posts
  • Flavorite Brew:Bud Light
Posted 11 March 2013 - 01:20 PM
Lg front load washer (WM2010CW), customer said it was out of balance. when i got to the house the washer was in use on delicate cycle. I stopped the cycle and opened the door to find the bellow twisted. Opened the top and found one spring off the tub and laying on the bottom and one damper busted as well as a tear in the upper part of bellow. Customer said they had a heavy load in it at the time of problem. I tried to reinstall the spring but could not stretch it enough to latch on top. My question is am I missing something (underlying problem) or should i just replace the parts needed: 3 dampers and bellow. Any tricks on getting the spring back on?
Thank,
Mike
#2 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,215 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 11 March 2013 - 04:35 PM
take an old dryer belt,hook it on end of the spring and use the belt to lift
this will give added leverage and make it much easier
*note*  once you get the spring back in its perch, the belt is trapped and you will have to cut the belt to remove it
hence the "old" belt remark
i have found several LG's with the springs popped off, never found any reasons as to what caused them you jump off the perch
quite often you can remove one side of the shock from its mount and reistall the 2 parts back togeather without having to replace the shocks
but... if you gotta go back with bellows, you might as well change the shocks
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
#3 john63
john63
  • 1,411 posts
Posted 11 March 2013 - 08:14 PM
<<<My question is am I missing something (underlying problem)>>>
Caused by a software glitch.
Affected only the LG WM2010 model with Serial Numbers ranging from 906KW & higher (i.e., 907KW/908KW/etc)
New MAIN BOARD needed (EBR43249701)
Redesigned DAMPERS (383EER3001F)
If DOOR GASKET is damaged---replace as well.
OUTER CLAMP/SPRING TOOL (383EER4001A)
INNER CLAMP/SPRING TOOL (383EER4004A)
To verify that MAIN BOARD has *not* already been replaced or updated...
Press & hold the SPIN SPEED & SOIL LEVEL buttons
Press the POWER button---and release all 3 buttons.
Wait until the door locks (single click sound)
Check the *Software Version*  displayed on the Control Panel...
Original/Flawed Main Board----> In:81/IU:00
Updated/New Main Board-------> In:81/IU:03
When re-installing the Tub Support Springs---secure the springs with ZIP TIES at the top of the cabinet (right side and left side).
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#4 bayouboy
bayouboy
    Ikkō-ikki
  • 35 posts
Posted 12 March 2013 - 08:33 AM
Thanks for the replys! and the heads up on the main control board. Waiting on the customer to decide on repair. Now with a possable need for a main board it just may put a nail in the coffin for him. Any warranty from LG on the board?
Thanks again!!
#5 john63
john63
  • 1,411 posts
Posted 12 March 2013 - 08:57 AM
Unfortunately,no.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#6 jb8103
jb8103
    Kohai
  • 459 posts
  • Flavorite Brew:Ginger ale
Posted 12 March 2013 - 10:39 AM
Connect the dots for me please, John - how did a software problem lead to this mechanical damage?
First, do no harm.
#7 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 12 March 2013 - 04:24 PM
not the lg expert like John but i would guess that it was a problem with it detecting the balancing issue that caused it make the tub jump around
#8 john63
john63
  • 1,411 posts
Posted 12 March 2013 - 08:30 PM
<<<i would guess that it was a problem with it detecting the balancing issue that caused it make the tub jump around>>>
Correct :)
Under "certain condition(s)"---the software will not adequately detect an out of balance condition.
I'm not entirely sure what "certain condition(s)" would be---but whatever it is---it somewhat explains why you'll encounter an over-one-year-old WM2010 washer with the Tub sitting on the floor and the Door gasket stretched/pulled downward.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#9 bayouboy
bayouboy
    Ikkō-ikki
  • 35 posts
Posted 14 March 2013 - 08:14 AM
The customer decided not to repair. Thanks for the help.
#10 Nasjar
Nasjar
  • 2 posts
  • Flavorite Brew:Bud Ice
Posted 02 April 2013 - 03:00 PM
Have a 2010CW that lights up display board when you spin the tub(door open, of course) Will not operate at all. Is my problem the Main Power Board or maybe the door lock ?
#11 RegUS_PatOff
  • 30,698 posts
Posted 02 April 2013 - 03:56 PM
... Have a 2010CW that lights up display board when you spin the tub
... Will not operate at all.
... Is my problem the Main Power Board or maybe the door lock ?
should start a New Topic ..
1) normal operation
2) Does the Display light up when you turn the Power ON ?
3) OR could be bad Wall Outlet power, bad Noise Filter, etc ..
#12 Nasjar
Nasjar
  • 2 posts
Posted 02 April 2013 - 04:02 PM
Will not power on, outlet voltage good(124) when tub is spun manually,all knob led's light and display shows straight line on each readout from L to R one after the other.
#13 john63
john63
  • 1,411 posts
Posted 02 April 2013 - 10:43 PM
<<<Will not power on, outlet voltage good(124)>>>
Likely a failed NOISE FILTER.
Usually a blown fuse/evidence of overheating---of the Noise Filter.
Can be tested...
Remove the top cover of the washer.
Pull the*pink* plug off the Noise Filter
Test for 120 volts at the *plug*----on the Noise Filter itself---not on the plug that was pulled off.
No Power=failed Noise Filter.
LG has re-designed the Noise Filter (high failure rate).
Original NOISE FILTER was----> 6201EC1006L
Revised NOISE FILTER----> 6201EC1006T
NOTE: On the RepairClinic website---there's a ***typo*** which states that the original Noise Filter has been updated from 6201EC1006T---to---6201EC1006L.
This is incorrect----disregard---and order the "T" version.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#14 Kokanee Ranger
Kokanee Ranger
  • 13 posts
  • Flavorite Brew:Kokanee ... the beer out here.
Posted 11 June 2013 - 11:41 PM
The first time I ran in to this I was helping a coworker change out the main board . He had already changed out the Hall sensor , rotter and stater or twice . Brought it back to the shop .
I had time and I worked on it . It would not spin up an unbalanced load ( One wet towel ). If it did find a balance it was
LG washer = Bucking bronco.
I checked the wiring harness to the motor , hall sensor. Found if I moved the harness around I would loss continuity on the blue wire going to the motor.
The wire was broken but outwardly looked fine.
When this unit went into spin and started to shake the motor would loss power to one of the banks of coils intermittently at high RPM..
Change out the Motor , Hall sensor wiring harness . Sorry no part number.
I have two on the go right now and it's 4-6 weeks to get a harness in from LG.
Must be a fast moving part. On washers that are 2 to 4years old.
#15 Kokanee Ranger
Kokanee Ranger
  • 13 posts
Posted 12 June 2013 - 10:21 AM
http://www.repaircli...ER1016B/1268330
Beware one large item can shake the top spring off . Just replacing damaged parts in this case can be a fix.
But If a LG washer spins up a normal load it senses as balanced and starts dancing across the laundry room.
Suspect the harness .
In this case I change the harness and Hall sensor. Hall sensor in considered part of the motor and is covered under the
10yr. Motor warranty.
:wink:
LG part number ( 6877ER1016B ) or the
Equivalent for the unit you are working on.
