Whpl front load lhw0050pq
9 replies to this topic
#1 jumptrout
jumptrout
  • 1,142 posts
  • Flavorite Brew:Coors Light
Posted 13 March 2013 - 02:48 PM
I have found out why you say run away from this washer.
Too late for me.
I am committed to it.
Original problem,leaking water.
Replaced the filter housing due to broken inlet from the dispenser.
It will take on water and the drain pump does work.
Otherwise,
Trying to test run the machine and the fuse on the motor control board blows.
Unplugged motor,replaced fuse turn the machine on,the fuse blows.
The board probably got wet when the housing inlet broke.
Removed the board and see no visible burned traces or components.
Service manual leaves a lot to be desired for my feeble abilities.
Anyone have any suggestions for finding the problem?
A new board is almost $800.00.
#2 RegUS_PatOff
  • 30,273 posts
Posted 13 March 2013 - 03:35 PM
can you post some good pictures of the top and bottom sides of that board ?
(can't see anything with cover on at RepairClinic)
#3 jumptrout
jumptrout
  • 1,142 posts
Posted 13 March 2013 - 04:24 PM
Will see if I can.
#4 jumptrout
jumptrout
  • 1,142 posts
Posted 13 March 2013 - 04:49 PM
Try these.
The little square on the backside looks a little tarnished. That is all I see.
  • Attached File  lhw.jpg   13.58K   12 downloads
  • Attached File  lhw1.jpg   12.75K   11 downloads
#5 RegUS_PatOff
  • 30,273 posts
Posted 13 March 2013 - 05:50 PM
13k ?
I was hoping for some bigger pictures ...
200k ?
1M ?
trying to trace the Motor pins ..
#6 jumptrout
jumptrout
  • 1,142 posts
Posted 13 March 2013 - 06:33 PM
Lets see how these look.
#7 RegUS_PatOff
  • 30,273 posts
Posted 13 March 2013 - 06:34 PM
still about 10k
need bigger pictures ..
what's the part number of that board ?
#8 jumptrout
jumptrout
  • 1,142 posts
Posted 13 March 2013 - 07:02 PM
The Merlomi # on the board is 546058301.
Part # W10581119 listed on Repair Clinic does not appear to be the same board.
Another # on the board is SBD20017A.M
#9 RegUS_PatOff
  • 30,273 posts
Posted 13 March 2013 - 09:48 PM
... # on the board is 546058301
this one ?
The manufacturer has replaced part number 546058301
with this item, part number 651050773
http://www.repaircli...umber=546058301
search for:  546058301
http://appliantology...-wcam1812-info/
#10 jumptrout
jumptrout
  • 1,142 posts
Posted 14 March 2013 - 06:39 AM
The mounting bracket plate would indicate that is the part.
Are there any SB's on the original part involving the fuse blowing?
The original fuse is 12 amp.
I only had 25 amp microwave fuses on hand.
It blew  them as well.
