2yr old Maytag oven stops heating after it heats up
6 replies to this topic
#1 bimbbobway
bimbbobway
    Sōhei
  • 232 posts
Posted 15 March 2013 - 09:52 AM
MGR7662WW2 all gas: Bake will preheat but a few cycles after, it will cycle on the burner will ignite but the ignitor will continue to spark 3-4 times then it stops with no power to the gas valve. After that it will not try to reignite untill you turn off & try again but it will not turn on the burner will just ignite & the ignitor will spark a few times & shut off again. There are no error codes. I feel it is not recognizing the flame. Any insight would be much appreciated. Thanks in advance.
www.mrappliance.com/wilmington
#2 Trying to help
Trying to help
  • 2,461 posts
Posted 15 March 2013 - 06:33 PM
It will not be your board or valve Bob. If it works fine on preheat board (spark board)  and valve are fine. You are loosing your ground feed. I have had good success by making sure igniter is properly aligned, heating can cause burner and brackets to flex just a little and a little bit is all you need. Also, where ever the burner touches chassis, I clean with my Dremel tool and a sand disc. Both the burner itself and what it attaches too. Last but not least the screws. If you order in a burner it usually comes with new screws which is usually a coarser screw to get a better bite. If all the above check fine, and you see no signs of cracks to your igniter, you probably have a burner issue. When I take my techs through everything and they state its all good boss and I have them order the burner the question it. But if you are sure everything else is fine, flame, alignment, ground and surface areas touching it.... what is left is the burner. I know your thinking, but what can be wrong with it, it's a hunk of aluminum with holes! Something is misaligned, flexing, something. Good hunting!
If we saved YOU Beer $$ today, please make a donation to our beer fund by clicking the link below to help keep this site going. I charge $135.95 PLUS PARTS to do this repair!$! http://fixitnow.com/beerfund.htm
#3 RegUS_PatOff
  • 30,242 posts
Posted 15 March 2013 - 09:17 PM
yes, and check the Wall Outlet polarity and ground
  • 24,281 posts
Posted 17 March 2013 - 01:21 PM
Right arm, TTH!  There was even a service bulletin out on this a few years ago, I posted the gist of it at my other site.
Bimbob, here's the upgraded burner.
#5 bimbbobway
bimbbobway
    Sōhei
  • 232 posts
Posted 18 March 2013 - 09:27 AM
Thanks. It makes sense about the upgraded burner. I tried repositioning the ignitor several ways with no success.
#6 bimbbobway
bimbbobway
    Sōhei
  • 232 posts
Posted 22 March 2013 - 06:19 PM
Well not the burner ignitor combo. Already had upgraded burner anyways. Been through all wiring & grounds still happening. I guess i may try a new dsi board.
  • 24,281 posts
Posted 22 March 2013 - 08:32 PM
Dayyam, budrow, I hate it when they don't give you enough info on the tech sheet or service manual where you can determine with certainty what the problem is and you're left relying on magic service bulletins and guess work.  I feel a haiku coming on...
DSI oven
Effed up like ol' Hogan's Goat.
Time for a good scream.
