maytag bravos m# mvw500xl0
ratcheting noise in spin
8 replies to this topic
#1 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 163 posts
  • Flavorite Brew:guiness
Posted 15 March 2013 - 03:19 PM
second  of these washers in as many days.really loud clicking in spin after 90-120 seconds.tilted washer back a bit and stuck my phone under to record and looks like the synch motor attached to drive system slightly disengages during spin,causing the plastic teeth of cam/clutch to bang into each other.is it likely the spring is weak? ordering the motor and that assy. anyone run into this ?
#2 applianceman97
applianceman97
    Sōhei
  • 116 posts
  • Flavorite Brew:Dechutes brewing co. Red Chair
Posted 16 March 2013 - 12:30 AM
Is the drive pulley tight? If not it causes the splutch to "grind". I have had many problems with that drive pulley nut backing off.
#3 tommytech
tommytech
    Sōhei
  • 163 posts
Posted 16 March 2013 - 07:57 AM
yes,its tight.newer washer,about a year old.p.o.s
#4 applianceman97
applianceman97
    Sōhei
  • 116 posts
Posted 16 March 2013 - 06:09 PM
i tried looking this model number up and couldnt. Is the model number listed correct?
#5 RegUS_PatOff
  • 30,209 posts
Posted 16 March 2013 - 06:13 PM
... mvw500xl0
from here, it looks like you model number is
MVWX500XL0
#6 applianceman97
applianceman97
    Sōhei
  • 116 posts
Posted 16 March 2013 - 07:18 PM
Its Whirlpools Virtical Modular Washer.  I actually really like these machines. Sorry i couldnt help more. The only thing i could think of would be the splutch and check to make sure that the tub is tight and in the correct location. (unlike the old whirlpools they have to be in a certain spot). Good Luck. Keep me posted on what you find.
#7 applianceman97
applianceman97
    Sōhei
  • 116 posts
Posted 16 March 2013 - 07:45 PM
Did a little more research. May be a bad transmission. Maybe these washers are not as good as i had hoped. lol.
#8 RegUS_PatOff
  • 30,209 posts
Posted 16 March 2013 - 08:33 PM
... Maybe these washers are not as good as i had hoped. lol.
:thumbsup:
#9 tommytech
tommytech
    Sōhei
  • 163 posts
Posted 17 March 2013 - 10:51 AM
i thought the trans was ok,washed normal .spin made no noise initially but after about 90 sec. very loud clicking noise,thats when i saw the gears on the splutch seperating,looks like a spring holds gears engaged when the synch motor slides the bottom gear over.
