ABB1927DES Amana Bottom Freezer unit with clogged evaporator. Refrigerator.
10 replies to this topic
#1 Sunlight Appliance
Sunlight Appliance
    Yamabushi
  • 70 posts
  • Flavorite Brew:Matcha Green Tea
Posted 16 March 2013 - 01:03 AM
Hi everyone,
My client has a bottom freezer-style fridge by Amana that is not letting cool air enter the fresh food compartment.
Complaint is: Freezer works great, but fridge is warm.
I disassembled the freezer and took a look at the evaporator frost pattern and it is just clogged to the max with ice. I tested the heater and the thermostat for continuity and they both are good.
There is a thermistor in the freezer compartment and a controlboard/display in the fridge. The damper is wide open and air is blowing through from the evaporator fan in the freezer.
I put in the manual request a few minutes ago. Whereto next, guys?
:thanks:
Edited by Sunlight Appliance, 16 March 2013 - 01:05 AM.
A little sunlight, a little cholesterol, and you'll be good to go :cool:
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,743 posts
Posted 16 March 2013 - 04:27 AM
On this fridge, only three items can cause a defrost failure. Heater, limit or the control (jazz) board. Through process of elimination, you probably have a bad board. You may be able to confirm it by putting the board in forced defrost mode. If your heater turns on, then your board is not going into defrost mode without being forced. But even if it doesn't turn the heater on during a forced defrost, your process of elimination supercedes board diagnostics so replace board anyway.
#3 RegUS_PatOff
  • 30,219 posts
Posted 16 March 2013 - 04:37 AM
16026201,pdf
yes, just about all that's left is the Jazz Control Board
http://www.repaircli...R=154&N=1541423
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 16 March 2013 - 06:39 AM
I have found more than one of these jazz boards that had the compressor relay stuck....so, even though it was defrosting on schedule, the thing never stopped cooling, and still eventually led to a clogged coil.
#5 BryanS
BryanS
    Yamabushi
  • Chief Appliantologist
  • 75 posts
Posted 16 March 2013 - 08:12 AM
More often than not the compressor relay on the board Kurtius mentioned is the problem. I found this out when I turned the temp to the warmest setting until the fridge should have been off, but you will hear the compressor keep running. Also look close at the defrost tstat. Sometimes they ohm fine but if you look close the top it may be slightly popped up.
#6 Sunlight Appliance
Sunlight Appliance
    Yamabushi
  • 70 posts
Posted 25 April 2013 - 01:52 AM
Thank you all.
This worked out okay. Replaced JAZZ board.
:thumbsup:
  • 24,258 posts
Posted 25 April 2013 - 07:39 AM
Domo for letting us know!
#8 PDuff
PDuff
    Sōhei
  • 178 posts
Posted 25 April 2013 - 08:14 AM
Jazz board has become standard truck item just like ge muddaboard. Went through 3 this week and it's only Thursday.
#9 micabay
micabay
    Ikkō-ikki
  • 51 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 25 April 2013 - 08:17 AM
Try turning the settings zero/off... Check the compressor to make sure it is off... A lot of times it will be running still when it should be off. And you can knock near the board to get the relay to shut off...
#10 DurhamAppliance
    Sho' Nuff Chozin
  • 1,743 posts
Posted 25 April 2013 - 09:38 PM
I got a jazz board the other day that wasn't split in two. Never had one like that before.  Freaked out a bit since I was terrified of snapping it for fear of breaking it. It snapped without incident although I had this perplexed look on my face.    So added another maxim to my ever growing list.....Always check your parts boxes and for God's sake, never open a parts box for the first time while in front of the customer.
  • 24,258 posts
Posted 25 April 2013 - 09:41 PM
Amen and amen! Learned that one the hard way.
