Maytag washer not spinning MAV4057AWW
2 replies to this topic
#1 bedwards0978
bedwards0978
    Ikkō-ikki
  • Chief Appliantologist
  • 35 posts
Posted 16 March 2013 - 01:12 PM
I have a Maytag washer that will not spin but agitates just fine. It will spin if there are not clothes in it and it will start spinning with clothes in it if I give it a little push start. It seems like this may be a brake problem, but I also know about the cam problems on these. Just wanted to see what you guys think.
When I took the cover off and lifted the unit to look at the belts while in spin cycle, the trans pulley is spinning fine and the trans is not turning.
#2 maytagman
maytagman
    Ikkō-ikki
  • 56 posts
  • Flavorite Brew:Spotted Cow
Posted 16 March 2013 - 03:33 PM
I think this is a atlantis type and your problem would most likely be fixed with a new thrust bearing kit.
I'm not near a computer right now to look it up, but the transmission pulley some washers a needle bearing and plastic cam make up the kit. Do a parts search and you will find it.
#3 applianceman97
applianceman97
    Sōhei
  • Master Appliantologist
  • 114 posts
  • Flavorite Brew:Dechutes brewing co. Red Chair
Posted 16 March 2013 - 07:21 PM
http://www.repaircli...mber=MAV4057AWW
Part number. 12002213
