LG washer showing LE error
washer lg
12 replies to this topic
#1 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 17 March 2013 - 04:47 PM
Here is the model wm2277hw and serial 503kw . I had sheets in it and then it stopped in the spin cycle. I have unplugged for hours nad turned back on. WIll not complete a cycle. I have also found the service manual and ran the QC test mode and it will not tumble clockwise at all . I am not sure where to start looking. I thought i overloaded it but nothing is working on getting it to run. Right now i am trying to run a no spin cyle just to let it finish but usually in the beginning it tumbles when you turn it on but didn't.
What steps should i take or am i missing something ?
#2 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 17 March 2013 - 04:53 PM
my wife says it smells like a burnt tire but I can not smell anyways. I did not think this model had any rubber in it unless it is the motor. How easy is it to take apart to see if anything is in there.
  • 24,722 posts
Posted 17 March 2013 - 07:12 PM
This is usually a bad rotor position sensor.  This page has details on how to verify and replace ==> http://fixitnow.com/...-le-code-video/
#4 john63
john63
  • 1,411 posts
Posted 17 March 2013 - 09:01 PM
<<<my wife says it smells like a burnt tire>>>
Built March 2005
All HALL EFFECT SENSORS were prone to damage on LG washers built before 2008.
However---what concerns me---is the burning rubber odor.
This is usually caused by the stainless steel tub lip making contact with the Door Gasket.
Very likely that the Tub Bearings and Stainless Steel Tub Trunnion are failing.
Grasp the stainless steel tub (also called: INNER DRUM) and pull/push---there should be *zero* movement of the s/s tub.
If play/wobble occurs---failed s/s tub and bearings (major repair).
Edited by john63, 17 March 2013 - 09:22 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#5 nickfixit
nickfixit
  • 1,990 posts
  • Flavorite Brew:Glen Livit
Posted 18 March 2013 - 06:34 AM
Friday I worked on one that had a bent/deformed spin basket. The bearings and seal were fine, but the basket made contact with the front tub. I think she washed pillows. Her complaint included the burning smell.
#6 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 18 March 2013 - 06:39 AM
Okay I will start checking. Thank you everyone. I have ordered the part and waiting for it now. Did you replace the basket or just reposition it ?
Edited by mmoore5553, 18 March 2013 - 06:40 AM.
#7 nickfixit
nickfixit
  • 1,990 posts
Posted 18 March 2013 - 04:32 PM
We replaced the basket assembly and rear tub assembly.
#8 john63
john63
  • 1,411 posts
Posted 18 March 2013 - 08:20 PM
Two different repair options...
http://www.repaircli...Number=WM2277HW
OR
Edited by john63, 18 March 2013 - 08:30 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#9 nickfixit
nickfixit
  • 1,990 posts
Posted 19 March 2013 - 04:34 PM
I wonder if roller bearings would be an improvement. The factory LG bearings seem pretty good, but whirlpool needs a new supplier. I would use synthetic grease and pack the area between the seal and front bearing
I bet you could use the Cabrio bearing tool to press the new bearings in. I wonder how hard it is too beat out the old bearings.
The LG part costs are pretty good compaired to Whirlpool
#10 john63
john63
  • 1,411 posts
Posted 19 March 2013 - 09:34 PM
<<<I wonder if roller bearings would be an improvement.>>>
I haven't replaced bearings on a Whirlpool Duet-design washer in awhile---the LG bearings *are* of the roller type though.
In 2008---numerous changes/upgrades occurred with various LG appliances---one of those was a change in the Tub Bearings.
The diameter/size of the current roller-type bearings are significantly larger than the originals.
<<<I would use synthetic grease and pack the area between the seal and front bearing>>>
The LG Tub Bearings are *sealed*---therefore---the synthetic grease would not be able to migrate towards the roller/bearings.
This *may* be possible---on other manufacturer/brand bearings---with exposed roller and/or sleeve-type bearings (I'm not aware of any such types of bearings used in late-model front or top loading washers).
<<<The LG part costs are pretty good compaired to Whirlpool>>>
I agree---it's a significant difference (of prices).
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#11 mmoore5553
mmoore5553
    Ikkō-ikki
  • 45 posts
Posted 22 March 2013 - 11:54 AM
just wanted to post back and thank everyone. It was the hall sensor. The burner smell went away after we replaced that sensor. I checked it with an ohm meter and it was reading infinity on one of the pins.
Just wa
#12 Samurai Appliance Repair Man
  • 24,722 posts
Posted 22 March 2013 - 12:18 PM
Good deal!  Domo for letting us know the outcome.   :thumbsup:
#13 john63
john63
  • 1,411 posts
Posted 22 March 2013 - 07:28 PM
<<<just wanted to post back and thank everyone. It was the hall sensor. The burner smell went away>>>
Good job :)
When the STATOR and MAIN BOARD are overheating from a failed/failing HALL EFFECT SENSOR---the odor will be an electrical "ozone" smell (not rubber).
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
