KUDI02IRWH3 Kitchen Aid D/W
Gremlins have taken over
1 reply to this topic
#1 jambatt
jambatt
    Senpai
  • Scholar of Appliantology
  • PipPipPipPip
  • 792 posts
Posted 18 March 2013 - 09:01 AM
Unit runs through cycles fine and then cuts off like it should. Few minutes later the unit restarts on it's own and runs through the cycles and shuts down. This continues until you cancel the cycles or you open the door or remove power by turning off breaker. Tech sheet doesn't address this issue.
Don't take life too seriously, none of us get out alive !
  • 24,698 posts
Posted 18 March 2013 - 03:28 PM
Check for a shorted keypad on the touchpanel.  If one of the cycle buttons is stuck closed and the door is closed, then the control will think it's game time.  You'll need to ohm out each pad in the ribbon connector while actuating the key pad and looking to see the resistance change from open to (near) zero.  Helps to have a micro lead set, I use this Radio Shack set and it's been peachy.
