This unit has an F2 error code. Tech sheet says it could be a temp sensor or board. It will display F2After about 20 minutes . Thanks.
GE Oven Mod#JTP95WCW1WW F2 error code
#1
Posted 18 March 2013 - 04:13 PM
#2
Posted 18 March 2013 - 04:37 PM
Does it warm up at all? If so, sounds like a temp sensor. You can ohm it out...1100 ohms +- 10% at room temperature but you may want to check it out at several higher degree points if you find 11k at room temp. Also check the wires connecting to the sensor. F2 generally means it is an excess or inconsistent temperature situation.
#3
Posted 19 March 2013 - 12:40 AM
It gets hot and goes to temperature. I'm sure its a sensor but these stupid GE tech sheets aren't as clear as it also points to a bad control.
#4
Posted 19 March 2013 - 06:48 AM
I've had f2 errors where the problem was a thermal fuse. Usually I test probe and fuse (if there is one), and reset ecm if possible before I replace a board on any oven, regardless of manufacturer or error codes.
With regards to tech sheet writers, the following question and response was found on 85 % of their requirement exams...
The problem is, their examiners consider it the correct answer.
- Samurai Appliance Repair Man, RegUS_PatOff and AARDL like this
#5
Posted 19 March 2013 - 07:11 AM
JTP95WCW1WW
maybe
JTP95W0W1WW
which is now
JTP95WW1WW
"Nobody told me there'd be math involved."
WB23X5340
http://www.repaircli...?R=154&N=253024
WB21T10007
http://www.repaircli...?R=154&N=911001
- Samurai Appliance Repair Man and DurhamAppliance like this
#6
Posted 19 March 2013 - 07:27 AM
LMAO! ![]()
- RedToryTy likes this
#7
Posted 19 March 2013 - 07:48 AM
I'm pretty sure the omh's at room temp for that sensor should read 1100 ohms NOT 11000 ohms, (maybe just a typo and you know that but it should be corrected for anyone who comes along later and reads this).
- RegUS_PatOff and DurhamAppliance like this
Eureka, CA 95501
#8
Posted 19 March 2013 - 09:18 AM
So true.....should have been more careful.....correcting it now. Good lookin out and thanks for pulling my arse out of the fire...uh..oven!I'm pretty sure the omh's at room temp for that sensor should read 1100 ohms NOT 11000 ohms, (maybe just a typo and you know that but it should be corrected for anyone who comes along later and reads this).
btw If anyone purchased a probe based upon the incorrect information I initially posted, provide model no. serial number, receipt, and mailing address and... let me see... oh yeah.. the Samurai... will be most happy to refund you.
- RegUS_PatOff likes this
#9
Posted 20 March 2013 - 07:19 PM
#10
Posted 20 April 2013 - 05:13 AM
Entrance Exam for Appliance Technical Data Sheet Writers
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 19 March 2013 - 07:24 AMRead Full Entry →
