GE Washer WPRB8050D1WW
Patricio
May I have a manual for this unit.  Will look at it tomorrow,  Compalint is does every thing but spin,  or clothes are still saturated after wash cycle.
  • Patricio
check the operation of the Water Level Pressure Switch (and tubing)
click on picture
