GE Washer WPRB8050D1WW
Does not spin
9 replies to this topic
#1 Patricio
Patricio
    Kohai
  • Chief Appliantologist
  • 438 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 18 March 2013 - 06:02 PM
Ideas what to look for in a complaint washer does every thing but spin.
IgonFishn & Tight Lines
#2 fairbank56
fairbank56
    Sōhei
  • 144 posts
Posted 18 March 2013 - 07:57 PM
  If the motor doesn't run and isn't humming, it's a bad control board. If the motor is running, check to see if the belt is slipping (no clutch pulley on this model). You should be able to freely rotate the motor pulley clockwise (viewed from below) which should turn the belt, main drive pulley, transmission and basket. You need to use two hands to keep the motor pulley going to keep the brake released. If it's very difficult to rotate, there may be clothing between the tubs or the split ring between basket and spin tube is bad. If the motor and main drive pulley are rotating but the transmission is not, then either the spring on the bottom of the transmission is broken or the brake cam is not working.
Eric
#3 aasnowskate
aasnowskate
    Ikkō-ikki
  • 27 posts
  • Flavorite Brew:pabst
Posted 19 March 2013 - 08:00 AM
lid switch
#4 RegUS_PatOff
  • 30,203 posts
Posted 19 March 2013 - 09:22 AM
check the operation of the Water Level Pressure Switch (and tubing)
http://www.repaircli...?R=154&N=963666
#5 fairbank56
fairbank56
    Sōhei
  • 144 posts
Posted 19 March 2013 - 10:07 AM
 Everything working but spin indicates the water level switch is working. Washer would not agitate if lid switch is bad.
Eric
#6 Patricio
Patricio
    Kohai
  • 438 posts
Posted 19 March 2013 - 11:36 AM
That is why asked if anybody Had an issue where washer would fill agitate & drain & not spin.     Call is 5pm this afternoon Probably something simple.  Customer is not giving complete information more than likely, probable doesnot agitate either.   Thanks for all input,  As always this site :dazzler: Rocks.
#7 Patricio
Patricio
    Kohai
  • 438 posts
Posted 19 March 2013 - 08:15 PM
Tub & basket Are locked up cannot turn any direction.  Agitator moves about quarter revolution.  Does not agitate although customer says it agitated last night with a load of towels.  Is the repair difficult on the transmission.  Peered down the sides of the tub Could not see anything between tub & basket.  customer stopped me from digging further ie. pulling basket from tub.  Unit was rusted on inside fairly good.  They decided to get new front load washer.   For further Knowlege can you explain what is invoved in repairing brake or spring on transmision?   Gracious
Edit side note: looking under tranny to pulley  I see oil/grease residue on shaft.
Edited by Patricio, 19 March 2013 - 08:34 PM.
#8 fairbank56
fairbank56
    Sōhei
  • 144 posts
Posted 19 March 2013 - 09:35 PM
  What is the main drive pulley doing when you run it in agitate and spin? Do you have the tech sheet from the washer? You can go into service mode and place it directly into agitate or spin mode from there.
Eric
#9 Patricio
Patricio
    Kohai
  • 438 posts
Posted 19 March 2013 - 10:00 PM
Main drive pulley is locked,  Motor turns barely but belt & pulley will not budge.  Put it in agitate & spin cycle.  Either something wrapped under drum & shaft or transmission locked.   Customer stopped me before I could pull agitator & agitator block.  Could not find anything where transmission could be rebuilt, nothing on the brake system.  All I could find was something on a coil spring that regulated the agitate & spin cycle.   Clue on some posts or videos on this tranny.
Could not find tech sheet on washer only what Samurai gave me on this site.
Do not know how to put it in service mode, never was able to find that info.
#10 fairbank56
fairbank56
    Sōhei
  • 144 posts
Posted 20 March 2013 - 08:00 AM
  Something caught between the tubs woud not prevent agitation. Pull the agitator, if nothing jamming it and you can't rotate the main drive pulley CCW (viewed from below), then the transmission is shot. Transmission is generally not serviceable as parts are not readily available. There was a kit available to repair the brake cam and I have seen the LGS spring on ebay but those would only affect spin. To get to service mode, press/hold the Whites and Start buttons until all led's light up (3 seconds). Now press Colors to go forward through the functions and Whites to go backwards. The functions are, model code, error code, hot valve, cold valve, agitate low speed, agitate high speed, pump and spin high speed. So press Whites once to go to spin high speed, once more to pump, once more to agitate high speed...etc.
Eric
Also tagged with one or more of these keywords: Does not spin
