Seasonal equipment advice
Snow blower lawnmower ethanol bad gas storage
4 replies to this topic
#1 Daveb1972
Daveb1972
    Yamabushi
  • Chief Appliantologist
  • 67 posts
  • Flavorite Brew:Boston Lager
Posted 19 March 2013 - 08:42 AM
This area (upstate NY) has a BIG problem with ethanol in fuel. The ethanol will separate from the gasoline as it ingests moisture and fall out of solution with the gasoline. The end result is low octane fuel, and a layer of water in the tank. Failure to deal with this will guarantee starting issues in the fall. There are 2 popular ways of dealing with this issue, first is to avoid fuel containing ethanol (very difficult to do) or add a stabilizer that has an enzyme that is supposed to maintain the miscibility of the ethanol in gasoline.
Gasoline that uses ethanol is made to a lower octane rating and the ethanol raises the octane level. When the ethanol absorbs water (which it loves to do, think dry gas) then goes through a significant temperature swing (seasonal changes) the ethanol/water blend falls to the bottom of the tank and is often the first thing picked up by the carb. The majority of old style stabilizers only dealt with the gasoline evaporative issues (“light ends” or the main volatile component of gas evaporates readily) leaving a varnish like substance. The “new fuels” don’t survive long enough for this problem to manifest.
The water that sits in the bottom of the tank can rot steel tanks, and will foul carbs when it sits in the fuel bowl.
My advice is:
Treat ALL seasonal fuels with  Star-Tron, or similar ethanol treatments.
Purchase only enough fuel for the season, and treat every batch
           (you never know when the last seasonal use is going to be)
           Treating all the fuel ensures the treated stuff is IN the whole fuel system.
Using a flashlight look into the fuel tanks and see if separation has occurred,
           If it has, dispose of the fuel, it isn’t useable. You can dispose of small (less than 2 gallons) in your car, if you
           have a mostly full tank.
Drain fuel bowls when possible, and use fuel shutoffs to empty fuel bowls (shut off fuel and run till stall)
            This can reduce the amount of muck that will deposit in the jet.
If you have contaminated fuel, and the machine won’t start, or seems under powered, remove the fuel, and replace
             with fresh treated fuel, including the fuel bowl. If that doesn’t fix it, you will need to have the carb serviced
             replacement needle and seat kits, are available, lets can often be cleaned, DO NOT ADJUST MIXTURES,
             they are set by the factory, and adjustment can violate emission laws.
Hope this helps with ethanol understanding, please look at the many online discussions of ethanol in gasoline for more tips to deal with it. Boat owners should be particularly wary of ethanol in fuel. The ethanol can destroy fiberglass tanks as well.
Thanks for your attention,
Chief Apprentice Appliantologist; Apliantology.org
Dave Bradshaw
ASE certified Mechanic
Nate Certified HVAC Tech
That which does not kill me only makes me stronger.....at this rate I'll be invincible by Tuesday!
  • 24,207 posts
Posted 19 March 2013 - 08:57 AM
Great advice, Dave!  Briggs and Stratton makes a good fuel stabilizer that treats up to 10 gallons of gas per container.
#3 Patricio
Patricio
    Kohai
  • 438 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 19 March 2013 - 08:37 PM
I use something down here called 'Mechanic in a bottle.'  works damn good also.  revitalises stal fuel.
IgonFishn & Tight Lines
#4 jmatthew
jmatthew
    Ikkō-ikki
  • 36 posts
Posted 09 May 2013 - 08:11 PM
Thank you for the info on ethanol and how it affects the engine.  My local mechanic has recommended sticking with 'straight' gasoline (no ethanol) whenever possible.  It is more expensive, but I notice an improvement in idle (smoother) and more power (subjective and not quantified.)
My tale of woe: I have a weed wacker, that has been hard to start, and losing power for years.  It is a 2 cycle motor, and I had been using the ethanol blended gasoline for as long as it has been available (ignorance on my part - and I am cheap.) Last year, it would not start, so I dismantled the engine, and found the main fuel hose and primer hose had become gooey and were dissolving. Has to replace the hoses and clean the carb to get the unit to start.
I understand that engines that can use the ethanol blend have hoses and seals that can withstand the effects of ethanol.
I usually use a gas stabilizer in all my power equipment fuel, and have been adding Sea Foam, again on my mechanics' recommendation.
#5 Adirondack Bob
Adirondack Bob
    Sōhei
  • 191 posts
Posted 10 May 2013 - 07:55 PM
Another vote for Sea Foam.
Sea Foam stabilizes for 2 years.
Sta-Bil for 6 months.
