I had a call and the people said the sensor mode wouldn't dry the clothes. These people live over 100 miles away so I replaced the control board and the sensor itself. Now they have called back and said the dryer won't shut off in sensor mode, that it starts all over. They said that it will count down and shut off in timed dry. Could somebody give me some possible causes for these symptoms? I know that I plugged in the all the connectors when I changed the control board and the sensor bars.
Samsung Dryer won't turn off in sensor mode.
#1
Posted 19 March 2013 - 11:37 AM
#2
Posted 19 March 2013 - 12:49 PM
model number ?
#3
Posted 19 March 2013 - 02:54 PM
DV218AEBXAA i forgot.
#4
Posted 19 March 2013 - 07:38 PM
had a lot of problems with the interface on these machines,which controls the main board ,i would check there
- Samurai Appliance Repair Man and DurhamAppliance like this
#5
Posted 19 March 2013 - 08:08 PM
... They said that it will count down and shut off in timed dry.
are the clothes then dry ?
#6
Posted 19 March 2013 - 09:32 PM
There's a service bulletin out on this problem that includes your model number. Problem description sounds very similar to what you're seeing.
- DurhamAppliance, tpoindexter and Ohm like this
#7
Posted 19 March 2013 - 09:42 PM
Also some info
- Samurai Appliance Repair Man, DurhamAppliance and tpoindexter like this
#8
Posted 19 March 2013 - 09:43 PM
Also some info
Nice! Domo, Brother Ohm-sweet-Ohm!
#9
Posted 19 March 2013 - 09:44 PM
- Samurai Appliance Repair Man and tpoindexter like this
#10
Posted 19 March 2013 - 09:45 PM
Guess we were posting at the same time!
The first Graphic is for testing the sensor function.
#11
Posted 19 March 2013 - 10:06 PM
I've not done Samsung warranty for 3 years now---and my Samsung memory is being over-written by incoming/new LG memory.
Sorta like a flash re-program using a jig. :)
Looking at my notes---the last time that I had a Samsung dryer was in 2009...
Model: DV218AEB/XAA
Serial: W04S54BQ901182R
Symptom: "Takes Too Long To Dry and Cycle Starts Over Again By itself"
Per Samsung Tech Center : Replace Main Board DC92-00160A
Problem solved.
I'd re-verify that the *correct* Main Board was installed.
If part(s) are ordered/obtained through a non-Samsung source---there's always a chance that the you'll receive the same defective/out-of-spec/non-updated part. Especially Main or Display Boards.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#12
Posted 20 March 2013 - 12:07 PM
Would the defective/out-of-spec/non-updated part have the same part number? I checked and I installed DC92-00160A.
