intelxual
KitchenAid Superba Stove KGRC707LBS0 : code F3:E3
6 posts in this topic
Hey there - hope someone can help.
My KitchenAid Superba Stove (model KRGC707LBS0) is throwing a code - and won't work.
The code is F3:E3
I checked this site first (of course), and tested two thermostats under the keypad (one worked with the test, one didn't). I also checked the thermocouple - it tested fine.
I replaced BOTH thermostats (ordered the wrong one first) but it's still giving that code ...
any experts have any thoughts? Was I going in the wrong direction?
Thanks in advance for your help!
Regards,
Kurt
f3 e3 registers as the oven is too hot.....this means  the probe is showing high resistance or your board is misreading it.  It may be the board but changing/testing probe is a lot cheaper and I've known probes to test fine but perform inaccurately.  Take the probe reading at the board. If you are getting a high resistance  like 3000 ohms then you may have a partially broken probe wire/harness.
F3E3 = Shorted sensor, always take reading from the control connection.
F3 E3 Keypad spill.
I be tho berry, berry confoosed!  How can one little ol' error code mean three different thangs?  Do y'all be's looking at the same tech sheet?
:wacko:
rooh oohh
I was looking at F2E3
