Troubleshoot modern appliances with confidence…
LG Lfx25976st Score - Fridge: 3 Repair Guys: 0
16 posts in this topic
This fridge an LG Lfx25978st, is kicking major bootay, and I may be next at bat. Customer called and said the flex mold Ice maker in the fresh food compartment is causing issues. Sometimes...not all the time....but Sometimes, the flex mold is not being returned to proper resting position. Happens often, no pattern, but the same 10% short of flat position causing ice and water falls. Sears went out twice, tried two new ice makers and a board.  Same problem. LG certified tech went out next, replace the Icemaker  a third time but same problem. Both Sears and certified company were talking to lg tech line while on site.  Official statement, engineering failure.   Customer got his money back but kept fridge.  He either wants to sell it or get it repaired and I'm the lucky person who will either buy it and repair it to sell or repair it for the customer. Deep down, something tells me to avoid it as it may be the first reporting of a potential recall issue.  Anybody have any clue what could be happening?
Even if you can't fix it, it's just an ice maker. Would make a nice spare frig. I'm assuming it's new.
yeah 2010 model...but when we sell things in our refurbished store..everything, ice makers, clocks and even indicator lights must work.. We are very picky like that but we are known and sought out because of it.
Hmm, randomly occurring event.  Adaptive defrost can act random, too, because it considers so many in-use variables.  Run the unit in your shop with your data logger in the freezer and compare freezer temp warmup times with the times noted when the tray fails to return to flat postion.  Could anything from water vapor getting in the ice maker guts during defrost and freezing to an EMF interference between the ADC and icemaker electronics.  Only thing I can think of to correlate and it'd be interesting to look at the graphs.
but would temps stop the tray from returning to normal position? I could understand it not initiating a cycle.  The thing is even when it is at 10-20% short of being flat, it will still call for water...which causes the water/ice fall.
Water vapor and electronic interference  are  interesting theories.  I can see where  data logging would help.
I didn't say anything about reselling it. Keep it for your loyal employees. Pack it full of beer and beef :yes:
I was imagining water vapor condensing on the mechanism or control board, re-freezing and causing problems that way.  Just a WAG.  Same with the EMF.  Probably something we would never imagine.  A temperature correlation might reveal some kinda pattern.
<<<Sears went out twice, tried two new ice makers and a board.  Same problem. LG certified tech went out next, replace the Icemaker  a third time but same problem.>>>
Problably no way to verify but---it's possible that the LG/Sears servicers and Technical Assistance are unaware of the following...
Beginning March 2012-----A 7th re-designed IceMaker kit was introduced to correct the symptoms that you've described.
Old Part Numbers:
AEQ7290401
AE17290402
AEQ7290404
AEQ7290405
AEQ7290406
As of March 2012---current icemaker part number is---> AEQ7290408
It doesn't surprise me they did not know it. I have little faith in Sears and that particular lg certified company that attempted the repair.Also I doubt Sears would have refunded $2000 without talking to LG extensively. But what doesn't surprise me, what I have lots of faith in and what I do not doubt is your ability and knowledge of LG appliances. I'm also sure your knowledge of many issues far exceeds that of some tech line paper pusher....so...back to the game in progress...
"bottom of the 9th..bases loaded...Tech's down by 3. there's a change in the line up....it can't be....no it isn't!....yes it is!..coming in at cleanup, is John63!" (crowd roars)
uh oh....AEQ7290408  is in the fridge already according to customer. It was put in by the last company with an icemaker kit dated Jan 2013 send directly from LG..
Strike one!.
<laugh>
Thank you, Durham.
It's still a rough guess---I usually like to post a reply---if I think that I have a greater than 75 percentile chance of being of real assistance.
I also recall that---several LG training seminars back---this icemaker issue was covered.
<<<I'm also sure your knowledge of many issues far exceeds that of some tech line paper pusher.>>>
Sadly---that's true in some cases. Although there are a few that are bright/knowledgeable/very helpful.
Whenever I call tech assistance---I think of Apollo 13 Cmdr Jim Lovell...
"Houston,we have a problem".
I'm expecting a Gene Kranz to answer the phone :)
Edited by john63
<<<and a board.>>>
Next pitch----a wicked Nolan Ryan knuckleball...
Verify that the DISPLAY BOARD (on the door) is the correct replacement---also manufactured Mar 2012 or later...
DISPLAY BOARD---->EBR67357901
Are we absoloutly sure the problem isnt external? I dunno, water pressure,gfi, floating ground, hell I dont know. Sound kinda flaky to me Does the flex tray not return every time or only sporadically. Rule of thumb is that an intermittant problem is almost always external. Forgive me but I think outside the box. Okay, time for my meds. ........
I work for Sears and we do use the 408. We have for quite awhile. Please enlighten us dumb Sears techs on how to fix this problem. We have guys that throw parts on and don't trouble shoot. We are all not all that way. The problem lies with management pushing to much work on us with very little time. I will say I went through many ice makers and it did fix some. Then others we just couldn't fix, so we tried valves and pcb. We don't get time to sit there all day when you are pretty much expected to run every call in 35 minutes.
i already asked about power issues. I'm also believe in thinking out the box. The only thing that bothers me regarding external issue is that when the tray falls short, it is always in the same position. Logic dictates it is not something as random as an external power issue. The failure occurs about 70 percent of the time. The fridge thinks the tray is the proper position since it attempts to fill it.
I have three thoughts.... 1) apparently with all the revisions made to fix an ice maker motor lock, maybe each revision fixed a group the next revision fixed another group including the previous group etc. Maybe another revision is needed to fix a smaller remaining group.
2nd thought... maybe the ice motor lock problem that is solved by replacing the icemaker is not the proper diagnosis.
3) Curious to know the inner workings of the ice maker motor ie at 90 percent of completion is a signal being sent or received by the motor. If so, that may give a hint as to what to look at next.
Its problem is it is now small electronic solid state devices made poorly.  Limit switch, replaced by sensor.  My thought pattern has words like, dead band, Hystersis (that means error tollerance)  like horse shoes, get it close and it thinks it's good.  Lots of these devices need to see the target and then it out puts lets say 5 vdc.  They can get to a point where they leak, let the voltage pass,   so in this case it may be just a poor diaod.
We had a porportional controller, that used a potentiometer on the wheel of a gear tied to the motor.  They would jump out of calibration range.
You will probally have to have the engineering design, and see what  device, type of limit, or sensor is used for detecting a flat tray.
I have seen things like a power supply cause the problem on a big PLC controlled oven,  The termicouple signal (thermistor in the case of new appliance)
was loosing it's feed, the oven would shut down.  The thermalcouples in this case use analog input cards to feed back the signal to the controller.
Our control folks changed out everthing including the backplane on this PLC.  They called in the company that programed it, set it up.  I asked them if the had changed the power supply, they told me that would not cause the problem. I didnt argue with them.  4 hours later the control guy asked me to go get the new power supply, they put it in and the problem went away.
I explained all this because if the device that detects the position of the bar uses an analog (variable) signal to detect it position as it moves in it's 360 degree rotation, then any loss of voltage, or increase of voltage (power) we use mil amps 4-20 for controls ,  could create an error.  Error band.  Dead band.
Dont know if I have explained it well.
