vunger1
mdb5130aww maytag dishwasher drain/fill problem
9 posts in this topic
Drains and fills at same time.  Any ideas? :rocker:
Is the drain hose connected correctly with a high loop?
Does the drain hose connect to a air gap device?
2 people like this
Is the drain hose routed through the floor to a connection below the dishwasher?
1 person likes this
Could also be a bad board, the relay for the drain pump or the water valve could be welded closed.
   I suspect that it is a bad relay. With the door open and drain/off selected....the machine begins to drain(and simultaneously at the same time) it runs water in for the durarion of the drain???
I think it would be the main board, but there is also a second board. Is there a way to be sure i get the correct board?
... I suspect that it is a bad relay.
... there is also a second board. Is there a way to be sure i get the correct board?
It may be a bad Triac on the Board
I only see one Board
http://www.repairclinic.com/referral.asp?R=154&N=949495
1 person likes this
OR it could be a stuck Water Inlet Vave (not likely)
With power to the Dish Washer removed,
disconnect the Water Inlet Valve under the front ToeKick Panel and try the Drain again
Stuck relay on the board?
