Learn how to be your own tech line…
dahbrown
Fisher and Paykel ED56 Dryer Rubbing Noise
4 posts in this topic
Hello All,
My F&P ED56 clothes dryer squeals during a cycle intermittently. It may last 5 - 10 minutes, and other times it comes and goes.
I suspect it may be the fan belt?
Any advice would be appreciated.
i will either be the bearings or more than likely the tension pulleys
Thanks for your prompt reply.
Once I pull apart the dryer would it be obvious by wear & tear what I need to fix?
If it is either the bearings or the tension pulleys would they need to be replace or adjusted or sprayed?
If the bearing is bad you will need to replace it. You may be able to oil the idler pulley, but changing it will ensure you won't have to tear into it again.
