WED5540SQ0 - Whirlpoor Dryer has trouble with thermal fuses...
26 replies to this topic
#21 sh2sh2
sh2sh2
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 756 posts
  • Flavorite Brew:yeunling
Posted 25 March 2013 - 05:21 PM
there shouldn't be any heat during air-fluff
Test again for a partial short or the Heater Element to chassis / ground.
That would also be a cause your original problem.
X2
#22 maytagman
maytagman
    Yamabushi
  • 63 posts
  • Flavorite Brew:Spotted Cow
Posted 25 March 2013 - 06:11 PM
I agree it sure sounds like a shorted element.  If it is shorted, it will start heating as soon as the timer is moved from the off position without the motor running. sometimes you can hear a vibrating noise and the element will start to glow a bit even when heating on 120volts.  Move the timer to the timed side with heat turned on and check for warmth on the heater housing.
#23 Scottthewolf
Scottthewolf
    Senpai
  • 2,944 posts
Posted 25 March 2013 - 06:35 PM
I've had this happen before. Replacing the heater element and thermal fuse fixed it.
Scott Wolf
#24 Applianceman97
Applianceman97
    Baby Sensei
  • 2,298 posts
Posted 25 March 2013 - 07:54 PM
Its happened to me. for sure sounds like a shorted element.
#25 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,210 posts
Posted 26 March 2013 - 08:25 AM
Heating Element Assembly
Heating-Element-Assembly-279838-00631722
#26 Centurion13
Centurion13
  • 7 posts
  • Flavorite Brew:Guiness Stout
Posted 26 March 2013 - 01:28 PM
I replaced the cycling thermostat completely.  Will test it again tomorrow on fluff.  Checked using a continuity tester for grounds on the heating coil unit, but did not detect any grounds or partial grounds.
What if the built-in heater on the cycling thermostat is not being activated by the mode selector switch?  Would a malfunctioning selector timer be a possible source of all this trouble?
steve
#27 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 26 March 2013 - 02:50 PM
If the Timer was keeping the Heater energized,
the Thermostat should still regulate the temperature.
