Troubleshoot modern appliances with confidence…
Randysacjj
LG Dryer
3 posts in this topic
Have LG digital dryer model  DLE2301R  will not run...Have tested high limit and belt broke switch ??? Not sue if it will need new main board now  ..Any Help would be appricated..
Have you verified power at the outlet?
Have you confirmed that you don't have an open neutral to the power supply at the outlet (need an outlet tester that lights up for this)?
Are you getting 120vac between the black and white wires on the main control board?
When you say it will not run do you mean it turns on and lights up but doesn't tumble or it doesn't even turn on?
