Roper Dryer blowing thermal fuse
5 replies to this topic
#1 kfnpemai
kfnpemai
  • 4 posts
  • Flavorite Brew:beer
Posted 27 March 2013 - 09:15 AM
Roper Model RED4440VQI
Wouldn't start so checked thermal fuse and it needed replacement.  Replaced it and dryer ran for about 5 minutes then blew again.  Any suggestions what to do next.
Kevin
    Shōgun
  • Master Samurai Tech
  • 31,391 posts
Posted 27 March 2013 - 09:23 AM
Was this the part you replaced?
If so, then there a couple of things to check out:
1.  The dryer vent may be clogged, restricted, external flapper stuck closed, etc., causing restricted air flow.  Restricted air flow in a dryer vent will cause the thermal fuse to blow.  For more info on dryer venting and air flow problems, see this post.
2.  Is the heating element staying on all the time, for example, when the dryer is running in air fluff (no heat) cycle, is the dryer still heating?  If so, then you may have a grounded heating element or the thermostat may be stuck closed.  I usually replace the thermal cutoff kit at the same time I replace a thermal fuse.
#3 kfnpemai
kfnpemai
  • 4 posts
Posted 27 March 2013 - 09:41 AM
Yes that is the part I replaced, I will follow-up on your recommendations.  But per the wiring diagram, the thermal fuse that I replaced is in line with the motor, not the heater element.  How do I check thermostat.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 27 March 2013 - 09:56 AM
yes, the Thermal Fuse is wired in-line with the Drum Motor,
but physically in the heated air-flow path.
When the air gets too hot, the Fuse blows,
and stops the Drum Motor which has its Centrifugal Switch controlling the Heater.
#5 kfnpemai
kfnpemai
  • 4 posts
Posted 27 March 2013 - 10:16 AM
How do I check thermostat to see if stuck closed ?
#6 RegUS_PatOff
  • 33,588 posts
Posted 27 March 2013 - 10:18 AM
more likely the other problems mentioned..
check those first
