deezus
Whirlpool Washer Mod#WTW4950XW0 wont spin
6 posts in this topic
this unit will spin if put in drain and spin but will not spin if in a normal cycle. It will wash and drain and fill then when it comes time for spin, the green light will stay on and it will just sit there and do nothing. haven't worked on many of these so any help would be appreciated, thanks.
error codes?  oops u beat me too it
Edited by sh2sh2
No error codes it doesn't have a display.
  It doesn't need a display to give error codes. Error codes are indicated by the status LED's while in diagnostic mode fault code display mode. Check the tech sheet.
Eric
Ok, if you look in the L-84 manual (link above) section 5-2 indicates which LEDs are lit for corresponding error codes---you will see this on page 5-6. The green LEDs will indicate which error code is being triggered.
