Kenmore fridge 795.75543401
herfdog
May I download service manual for this model? Freezer drain froze up and defrost works. Is there a heater kit or probe for this drain
This refrigerator is made by LG. Not sure about a drain heater kit but if you could find one for an lg it should work.
Check the drain tube under the fridge. I had a lg made kenmore with a clogged duck bill check valve at the end of the tube and another where the tube slid down to where the check valve (this one had a flapper style valve on the end) was wedged against the bottom of the drain pan. Both lg made kenmores and neither valve appeared on the diagram. It may be part or the tube itself.
  • 2 months later...
Not sure if you are aware and although not related to your issue...there has been a recall on this model with serial numbers 405KRxxxxx through 410KRxxxxx
The recall involves repair to condenser fan motor short circuiting
.....http://www.cpsc.gov/en/Recalls/2005/CPSC-LG-Electronics-and-Sears-Roebuck-and-Co-Announce-Recall-to-Repair-Refrigerators-/
