LG Washer Door Boot Inner Spring Clamp Removal Tool
LG washer door boot gasket tool 383EER4004A
30 replies to this topic
#21 john63
john63
    Dean of LG Appliantology
  • 2,218 posts
Posted 31 March 2013 - 10:58 PM
Not that I'm complaining---Durham :)
Any discussion on tools is always interesting to read...
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#22 tpoindexter
tpoindexter
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 668 posts
  • Flavorite Brew:Beamish
Posted 31 March 2013 - 11:01 PM
Ok, here's my favor tool. It comes with a charger, 2 batteries, it's variable speed, and has 3 led lights around the end to light your way. The battery stays up for over a week using it everyday on every job. It's very compact and powerful. It is an impact but its such a high quality tool (you can feel it when it's in your hand) once you get the hang of the variable speed trigger that's not a problem.
Bosch 12-Volt 1/4-in Drive Cordless Impact Driver
Item #: 155138 |  Model #: PS41-2A
Test
#23 john63
john63
  • 2,218 posts
Posted 31 March 2013 - 11:08 PM
<<<Bosch 12-Volt 1/4-in Drive Cordless Impact Driver
Item #: 155138 |  Model #: PS41-2A>>>
Good quality drill.
I have one---but use it around the home---currently using the Milwaukee 12 volt drill.
The Bosch PS41 impact tool sounds like a *jackhammer* while removing/installing sheetmetal screws from $1000 washers/dryers.
Some customers noticeably became alarmed at the BAM-BAM-BAM-BAM! noise caused by the drill :)
Read more: http://appliantology...2#ixzz2PBHvZiDb
Follow us: fixitnowsamurai on Facebook
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#24 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 31 March 2013 - 11:17 PM
Well Since this post was started by the Samurai, maybe it's okay to hijack it!  lol
love the bosch....did a mini review of it at christmas time  http://appliantology...-combo-set-112/  it's my favorite.
but to go in my micro bag...I use  sklr2354-02-rt_zps78be5c83.jpg   Love the small size and 90 degree attachment.
www.DurhamApplianceThrift.com
#25 tpoindexter
tpoindexter
    Senpai
  • PipPipPipPip
  • 668 posts
Posted 31 March 2013 - 11:43 PM
I thought it was too noisy to at first then the more I got used to using it the easier it was to use without being so noisy.
It can be getting some screws out if they are really tight, but, that's where the right amount of pressure and the variable trigger can help keep that to a minimum. If it hammers putting them in you have them cross threaded.
I've never had any problems with customers, but, my customers know I'm respectful of their appliances.
Edited by tpoindexter, 31 March 2013 - 11:51 PM.
Test
#26 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 31 March 2013 - 11:51 PM
When i purchased it , both the impact and non impact versions came in the kit..  I use the impact at home and the standard version at customer's house....no noise.
#27 tpoindexter
tpoindexter
    Senpai
  • PipPipPipPip
  • 668 posts
Posted 31 March 2013 - 11:55 PM
Maybe I should get one and try it. It's a win win because I'd always have the other as backup if needed.
Test
#28 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 01 April 2013 - 12:16 AM
 Also you can use drill bits in the standard model. The impact model makes it harder to use drill bits for safety reasons I assume
#29 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,920 posts
Posted 01 April 2013 - 07:16 AM
Someday I might make a toolbag video
Would love to see that!  Let's compare armaments:
<<<How did you get enough room to remove the control panel screw inside the machine with the top panel just slid back? It only slides back a few inches. Did you use a stubby or offset ratcheting driver?>>>
For a stacked LG washer/dryer----not "shoehorned" into a tight location---slide the washer top cover and dryer rearward about 1 to 2 inches.
Carefully lift/push dryer (tilt back) and place a small 2x4 wood block at each corner.
Use stubby phillips.
Keep your 3rd eye on the dryer at all times during the repair process---especially if it's a gas dryer...
Good tips, Domo, John!
#30 Samurai Appliance Repair Man
    Shōgun
  • 30,920 posts
Posted 01 April 2013 - 07:21 AM
My topics are always hi-jackable!   :dude:
#31 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,307 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 01 April 2013 - 07:50 AM
i prefer to take the front panel off the LG washers, i find it faster taking the front off
however...  if i am stuck by myself and there is a stacked dryer, i can change the boot with the front on
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
