Sign in to follow this
Followers 0
AlexM
Whirlpool Stackable W/D Model# LTE5243DQ9, Mystery Cuts on Tub Ring and Agitator
6 posts in this topic
This stackable seems to be working correctly, but I can't figure out what is causing the cuts in the tub ring and the agitator cap.  the customer swears they haven't been washing razor wire.  Is this common?
post-71964-0-12662600-1364956477_thumb.j
post-71964-0-80129000-1364956497_thumb.j
post-71964-0-59367400-1364956573_thumb.j
Maybe they've been washing blocks of concrete? That is not common.
I have know idea what I'm going to tell my customer, but I just had a great belly laugh at your response...Thanks, I really needed that.
Are you sure the ring is attached properly? But I've seen something similar on these small laundry centers and stackables when a shock pushed through it's support plate. The shocks have been redesigned but check the plate under each shock. It may look okay on first inspection.
I pulled the ring off to inspect for something caught between the tub and basket, it came off and went back on, much like I would expect.
Then check the shocks and plates
Followers 0
