KM wall oven 911.47456590 throwing "F2"
4 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 996 posts
  • Flavorite Brew:Newcastle Brown Ale--"The Beer of the Working Man"
Posted 03 April 2013 - 01:42 PM
To the Dojo,
I've got this wall oven overheating, to the point of burning up the sensor connection. Ohming the sensor: 1090 (A-1, good resistance); ohming at the J1 connector: 1330 ohms. So I've got an exposed wire somewhere. My plan of attack is pulling out the oven, removing the back cover, and ohming each wire to ground and hunting for the broken covering. I had a dryer do this once, so I've got experience. Any additional strategery, critical comments, snide remarks, or pointing out any glaring errors in planning my attack?
Thanks in advance,
Tyrus
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 03 April 2013 - 02:13 PM
... of burning up the sensor connection.
Sensor connections where ?
if you're talking about the connections at the end of the Sensor wires,
they shouldn't be inside the Oven,
but on the other side of the back Oven wall
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 6,073 posts
Posted 03 April 2013 - 10:08 PM
Sounds to me like the sensor connector went bad causing the oven to overheat causing it to burn the sensor connector which causes it to overheat causing it to burn the sensor connector......see... It's like "the song that never ends"
Anyhow, I would replace the sensor regardless of test results. Many new replacement sensors require bypassing the molex connector. If not, bypass it anyway and splice it in, cutting off as much of the old wire as possible.
www.DurhamApplianceThrift.com
#4 RegUS_PatOff
  • 33,588 posts
Posted 03 April 2013 - 10:12 PM
... keeping the connections behind the back wall of the Oven ...
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 6,073 posts
Posted 04 April 2013 - 08:31 AM
The deterioration probably started after a self clean (self destruct) cycle.
