GE Refrigerator Evaporator Frosting Up
4 replies to this topic
#1 ApplianceDoctor
ApplianceDoctor
    Yamabushi
  • Chief+ Appliantologist
  • 73 posts
Posted 04 April 2013 - 08:00 AM
I have GE refrigerator M # GSS22JFMDCC, evaporator is frosting all the way through it, but top half of evaporator coil has excessive frost and some ice. This does not look like a normal defrost problem. I bypassed board with jumper wire and defrost heater came on which usually indicates a bad sensor. But with the excessive frost and ice on top half of evaporator I am not 100 percent sure. Does this sounds like a sealed system problem? Can anyone help me. Thank You
Appliance Doctor
    Shōgun
  • Master Samurai Tech
  • 30,715 posts
Posted 04 April 2013 - 08:14 AM
Sounds like a classic case of a bad evaporator thermistor (clipped to the evaporator) causing incomplete defrosts.  It gets water in it which raises its resistance and makes the muthaboard think it should stop defrosting too early.  Check the resistance of that thermistor with it dunked in a glass of ice water, should get around 16 k-ohms.  Measure the resistance from its wire harness connector back on the muthaboard.
Evaporator Thermistor
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 April 2013 - 11:00 AM
... and make sure all of the Thermistors are the "newer" type
#4 ApplianceDoctor
ApplianceDoctor
    Yamabushi
  • 73 posts
Posted 12 April 2013 - 09:19 PM
Thanks for all your help
#5 vincef
vincef
  • 18 posts
Posted 17 April 2013 - 12:36 PM
Also on GE thermistor replacement, Use a crimp style wire nut and fill the bottom with silicone so moisture cant get into the connection.
I learned this one the hard way... on my own refrigerator.
VF
