Today's appliance engineers should be forced to work on the stuff they design
44 replies to this topic
#21 DurhamAppliance
    Sho' Nuff Chozin
  • 5,463 posts
Posted 17 July 2013 - 09:09 PM
Had a standard Ge profile warm fridge repair today... Fridge was dead other than lights. No problem, stuck in defrost or temp sensor failure. Customer said "you know, i had a problem with the ice maker water line in the back of the fridge where re it connects to the ice maker water feed tube. " Okay, " I said dismissively, thinking hey let me work on one problem at a time. Then, i loosened the screws to the mainboard compartment and water cascaded out of it.
"WTF?" Never seen that before. Customer said, "I told you the water line came loose." And sure as shooting the board is sitting directly under the icemake line connection to the water spout. Hellbells, I thought for sure that compartment would be at least water semi-tight. Not! What too dumb to ride the small bus moron came up with that design?
www.DurhamApplianceThrift.com
#22 MAPS Appliance Repair
    Yamabushi
  • Appliantologist
  • 86 posts
  • Flavorite Brew:coffee
Posted 31 December 2013 - 08:08 PM
Hey I found the evap fan motor in the bottom mount GE fridge. I should be a actor.
#23 olyteddy
olyteddy
    Kohai
  • 376 posts
  • Flavorite Brew:Earl Grey
Posted 01 January 2014 - 01:26 AM
Drawer or Door model?
#24 BryanS
BryanS
  • 1,493 posts
Posted 02 January 2014 - 12:14 AM
I thought I read or a former Sears coworker said the NLA board problem with Whirlpool was due to damage of an overseas plant that was hit by a tsunami. I forget where I heard that, but apparently that is why the built-in refrigerators boards have to be sent off to be rebuilt.
Edited by BryanS, 02 January 2014 - 12:14 AM.
#25 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
  • Flavorite Brew:What's on tap?
Posted 02 January 2014 - 11:26 AM
:soapbox:
So, Whirlpool announced that it will stop selling the sump assembly for the Global Wash System (GWS) as a all-in-one replacement part due to the fact technicians are not taking the time to properly diagnose the individual components.
This thing leaks in two areas:
A) The discharge hose blowing off the wash pump, attached with factory crimped clamps that can not easily be replaced.
B) Another great source of leaks is the diverter motor seal, which destroys the diverter motor and corrodes the attached harness connections. The seal is factory pressed into the sump, sump replacement is required, along with diverter motor and sometime the wire harness...
Sump assembly replacement takes about 20 minutes. Replacing individual parts takes much longer and can cost more.
That's my 2 cents...
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#26 Applianceman97
Applianceman97
    Baby Sensei
  • 2,283 posts
Posted 08 April 2014 - 12:52 AM
Just replaced a drain pump on a Frigidaire dishwasher today. Who in the hell came up with putting the pump motor in the back of the sump assembly. Had to slide the whole dishwasher out. Remove the circulation motor cover and remove the 3 screws. I wanna kick that engineer straight in the nads.
Edited by applianceman97, 08 April 2014 - 12:53 AM.
#27 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
Posted 08 April 2014 - 04:45 AM
Samsung range, must remove cooktop to replace broiler. Added bonus: Replacement broiler does not fit into original brackets...
Edited by Chat_in_FL, 08 April 2014 - 04:46 AM.
Mother Teresa
Big Brother
#28 DurhamAppliance
    Sho' Nuff Chozin
  • 5,463 posts
Posted 08 April 2014 - 06:20 AM
You're kidding right? April's fool day is long past.
#29 Applianceman97
Applianceman97
    Baby Sensei
  • 2,283 posts
Posted 08 April 2014 - 10:07 AM
That's insane!
#30 PDuff
PDuff
  • 2,034 posts
Posted 08 April 2014 - 02:57 PM
Makes perfect sense in the Samsung universe.  :borgsmile:
#31 Scottthewolf
Scottthewolf
    Senpai
  • 2,943 posts
Posted 08 April 2014 - 03:24 PM
Need to charge double on some of these bad designs when they are out of warranty. If you do warranty, you need to talk to the manufacturers that these dumb designs are why you want higher labor rates to do their warranty work otherwise they can go pound sand.
Scott Wolf
#32 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
Posted 09 April 2014 - 04:40 AM
Luckily, had a preview via a service manual, else I would have done serious damage trying to access said broil element from oven:
Remove cooktop
Get lock assembly out of the way
Remove heat shield
Remove broiler box
Remove clamps near terminals
Flip broiler box over
Remove cover
Remove more clamps
Replace extremely fragile glass broil element
Reverse process...
shake head in disbelief..
Edited by Chat_in_FL, 09 April 2014 - 04:49 AM.
Mother Teresa
Big Brother
#33 PDuff
PDuff
  • 2,034 posts
Posted 09 April 2014 - 08:45 AM
When Samsung was first introduced into our local market, every servicer I know signed up to be warranty authorized, including us.  Now, every servicer in the area has dropped Samsung, including us.  Who does that leave....A&E?
#34 Scottthewolf
Scottthewolf
    Senpai
  • 2,943 posts
Posted 09 April 2014 - 10:27 AM
I see they finally wised up on their refrigerators. The defrost heater is now a Calrod heater and is finally replaceable separately from the evaporator.
Scott Wolf
#35 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
Posted 10 April 2014 - 08:36 AM
Dent in GE dishwasher door panel. No biggie, 15 min job... Wrong!
Have to remove door from dishwasher to replace front panel.
Struggle to find hidden screws before calling for tech assist, something about releasing the tension on the hinge spring linkage, only then I realize they meant so the door could be removed.
Giant jigsaw puzzle with tabs and slots that don't want to slide back together after being separated.
90 mins later, dented SS door replaced with new panel covered with sweat and fingerprints.
Next one should only take about 30 mins now that I know how it works...
Edited by Chat_in_FL, 10 April 2014 - 08:37 AM.
Mother Teresa
Big Brother
#36 Patricio
Patricio
    Opa
  • 1,502 posts
  • Flavorite Brew:Home brewed ice tea
Posted 10 April 2014 - 10:57 AM
Make a video by any chance to share?   Something i need to start doing.
I see says the blind man, leading a lame dog, while talking to a deaf person. In other words, Not liable if you choose to follow my opinion.
IgonFishn
#37 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
Posted 10 April 2014 - 11:03 AM
Hind site is 20/20... If I had realized what a project I was in for, I may have had the foresight to document the steps. Maybe next time I run across one I'll think to document with photos  :sad:
Edited by Chat_in_FL, 10 April 2014 - 11:03 AM.
Mother Teresa
Big Brother
#38 Scottthewolf
Scottthewolf
    Senpai
  • 2,943 posts
Posted 10 April 2014 - 03:20 PM
I have a video demonstration on the whole dishwasher if anybody is interested in it I can e-mail it to you.
Scott Wolf
#39 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • PipPipPipPip
  • 903 posts
Posted 10 April 2014 - 03:59 PM
I've done those before, I was lucky the first time because I always pull out the mini-manual (tech-sheet) and run a full diagnostics before I do a repair. But the mini-manual actually stated about how to remove the door. So no swear, blood lot tears on my part.
If I wouldn't have seen it in the manual I could only imagine trying to figure that one out..
That would have been a B!1t@h
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#40 B4UTRUST
B4UTRUST
    Sōhei
  • 130 posts
  • Flavorite Brew:Monty Python's Holy Grail Ale
Posted 10 April 2014 - 08:10 PM
Remove cooktop
Remove heat shield
Remove broiler box
Remove cover
Remove more clamps
Reverse process...
The new infrared broilers on the LG ovens are the same way. Had to replace one once and it was a royal PITA to say the least.What should have been a 15 minute job to swap a broil element turned into an hour job. So Samsung is not alone in this one. Maybe it's a Korean thing?
Owner/Operator Flagship Appliance Repair
