jlb813
Dacor Range Electric/Gas Combo ERD36SBK/LP
6 posts in this topic
The bake element is not getting power. I want to check the power at the relay board, but I do not know what to remove in order to get to it. I can see the board behind the front grill, but I don't have any idea how to access it. Does anyone know how to get to this board? Do I need to remove the top frame? If so, what tool do you use to remove the brass nuts?
Thanks for the link. I still don't see anything that tells me how to get to the relay board. The parts manual makes it look like I have to remove the top frame, but it doesn't list a tool to use for removal of the brass nuts. any help will be appreciated.
A final update. I purchased the removal tool (Thanks Russ Tech), removed the top frame and gained access to the relay board. The relay board had a burned connection and while I was comfortable with soldering it, the customer insisted on a new board. I replaced the board and all is well. Thanks for all the help.
2 people like this
If you have a burned connection at the DBL break line relay on the relay board, you need to check for a loose L1 connection where the range's power harness connects to house power.  May find a loose wire nut or an improperly done aluminum to copper splice.  If the problem isn't corrected, it'll burn out that relay again and you'll be back.
1 person likes this
